Mike G
- First Name
- Mike
- Jan 6, 2022
- N. AL, USA
- 2022 F-150 Lightning, 2023(J1) Mach-E GT-PE
Issue: Some 2022-2024 F-150 Lightning vehicles may exhibit an intermittent inoperative power hood (frunk)
during opening and/or closing with a Frunk Fault Service Required message in the IPC with DTC U2001:68 in
the FHCM with no other DTC stored in the FHCM. The power hood (frunk) will still open when using the manual
lever release and close when pressed down manually. This may be due to the software level of the FHCM. To
correct this condition, follow the Service Procedure to reprogram the FHCM to the latest software level using the
latest version of the FDRS scan tool.
