Distance to destination on dash = 0kms
user-name-required
T
BC
2024 F150 Lightning Flash, 2023 ID4 pro S
Hey all
Have been noticing this lately in my truck, wondering if others have as well. When you set a destination via android auto, on the main screen it is still accurately showing the distance to arrival, time to arrival, and % SOC at arrival....but on the dash, it shows a 0.00 km distance to destination.
It knows I have set a destination, as it has the little checkered flag there and the area for that distance to show below the estimated remaining range, but the distance to destination is 0kms.
Any ideas here? Anyone else have this?
Ford F-150 Lightning Distance to destination on dash = 0kms Dash distance remaining 0
Ford F-150 Lightning Distance to destination on dash = 0kms PXL_20260123_005636389
fhteagle
D
'22 Lightning Lariat, '23 MYLR, '13 Forester, sold '13 Volt
Not sure exactly when this behavior changed, as it used to show up there. But in my last real trip, at no time did my android auto destination show on the range display.
It only recently showed up in gmaps but now doesn't show. It never showed for me in Waze.
21st Century Truck
Martin
Often, strange behavior like this can go away by resetting the APIM. Depending on the screen (12 inch or 15 inch screen), resetting the APIM is done by two touch screen buttons or two physical buttons and takes just seconds.
I tend to do this every month or so, and on every long trip, to clear out the APIM's cache corners.
A search here for "reset APIM" will uncover the procedures for either screen.
Mal106
Mal
SW VA
2025 Lightning Flash
Retired Pilot
Mine is doing this as well. Resetting the APIM did not work nor did restarting the phone. Happy to know it's not just my '25 Flash.
It is a GoogleMaps issue. Resetting the vehicle won't do squat.
jwrezz
1996 Ford Explorer, 2006 Subaru Outback Sedan, 2024 Ford F150 Lightning
Teacher/Firefighter
I had this when using waze, but not with google maps.
I noticed the same issue on recent road trip, the distance to destination with Ford Nav is fine but missing while using Google Maps you need to look at the center screen quickly before blue cruise catches you with averted eyes, it would be nice to have that on the IPC.
I wonder if this is a failure of android auto / Google maps integration?
Ford F-150 Lightning Distance to destination on dash = 0kms 1769377349194-rr
Ford F-150 Lightning Distance to destination on dash = 0kms 1769377546125-n
Mal106
Mal
SW VA
Retired Pilot
Almost certainly. Carplay is OK.
B177y
Olympic Peninsula, WA
2024 Pro SSV ER Max Tow
It's a Google maps bug from a recent Google Maps update.
Uncheck "Auto update" (Auto update off) in the upper right menu while in the Google maps app of the play store. Then click the "uninstall" button. It will ask if you want to "delete all updates", click yes. Reboot phone when finished.
You can't uninstall GMaps unless you are running a custom version of Android, but you can delete the updates. After you delete the updates, everything will work again.
fhteagle
D
So my android auto app version just got bumped to
version 15.9.655114-release
com.google.android.projection.gearhead
versionCode 159655114
targetSdk 36
minSdk 32
Installed: Jan 21, 2026; 16:12
Updated: Jan 27, 2026; 00:48
But I still have the 0 mi to next stop bug. Yay.
targetSdk 36
minSdk 32
GoogleMaps...
Uninstall GoogleMaps updates and turn off auto updates for that app. Find apk for prev version, and install it.
Markip
Barrie Ontario
2025 F150 Lightning xlt
Manager of Operations
I am a google maps Beta tester and it also has the same glitch.
