msadan
- First Name
- Dan
- Nov 29, 2022
- Lafayette IN
- 2023 F-150 Lightning Pro, 2025 Tesla Model 3, 2010 Tesla Roadster
- Occupation
- Pinball repair
Here's a strange one: When I look at the Car Scanner data it shows that the parameter for high voltage battery age has been reset. Also, my HVB state of health has dropped from 99% to 87%. Charging to 100% shows no obvious battery issues, in fact at 100% SOC displayed it's showing 100.35 kWh on my SR pack.
I had been having intermittent (and then consistent) issues with the truck not communicating with the Ford app, so I tried a Sync reset, Sync master reset, pulling fuse 8, and then pulling the battery's negative cable, all with no results. After removing and reconnecting the three cables at the TCU (with fuse 8 removed) the truck started communicating with the app again, and it's been working fine for a few days now.
Immediately after this is when I noticed the HVB age reset.
None of what I did seems like it should have caused the HVB age to reset. And I know that the SOH figure is somewhat meaningless, but it's odd that it's dropped so low when everything seems to be fine. Truck is a 2023 Pro SR.
