TSB 24-2103, 2022-2024 F-150 Lightning Intermittent Frunk Open/Close - with DTC
Mike G
N. AL, USA
Issue: Some 2022-2024 F-150 Lightning vehicles may exhibit an intermittent inoperative power hood (frunk)
during opening and/or closing with a Frunk Fault Service Required message in the IPC with DTC U2001:68 in
the FHCM with no other DTC stored in the FHCM. The power hood (frunk) will still open when using the manual
lever release and close when pressed down manually. This may be due to the software level of the FHCM. To
correct this condition, follow the Service Procedure to reprogram the FHCM to the latest software level using the
latest version of the FDRS scan tool.
The Weatherman
Dean
South Central KY
Thanks for the information.
WHPHLightning
2023 Ford Lightning XLT
My 23 is experiencing this....back to the dealer it is....
sean7512
Sean
Pittsburgh
2024 Lariat | 2023 MachE GT
@Mike G is this something that could be looked up by VIN to see if my truck needs the update? I have see that message twice since taking delivery in October and it has worked immediately after when opening from FordPass. Both times I got the error when trying to open it with the physical button inside the car.
Mike G
Mike G
N. AL, USA
Very likely.
