12 volt battery indication - issue?
K6CCC
Glendora, Calif.
2024 Lightning Flash ER in Antimatter Blue, 2017 Toyota Corolla (wife's car)
Two Way radio systems
Sanity check since the manual does not really give much info.
If I turn the truck on into accessory mode, I immediately get a battery indicator light on the dash. That never clears until I either shut off the truck or turn it fully on. My understanding is that this is not normal. Been this way since day 1. Can someone confirm this?
Since I need to take the truck in for the upper control arm ball joint recall, if this is not normal, I will have them address this as well.
Normal, the HVB contactors are open in this mode and are not providing energy to the DC/DC charging inverter.
MaintGrl
Marsha
El Sobrante, Ca
Just like ICE, your running off of the 12v Battery....
K6CCC
K6CCC
Glendora, Calif.
I fully understand both of those. But that is not a "problem" as would be indicated by the dash light indication. As I said at the beginning, I recall reading here that what is normal is that at boot up the indication will display and it SHOULD then go out unless the 12V battery is in trouble. Mine never goes out while in accessory mode. Works fine when "On" and therefore the HVB is providing charge to the 12V system.
Guess I will ignore it.
If that was said/written then it was a miss-statement, the lamp is a REMINDER that you're draining your LVB simple as that.
If it stays on while in RUN/READY TO DRIVE mode, then you've got an issue with the DC/DC charging system.
K6CCC
K6CCC
Glendora, Calif.
Got it.
Adventureboy
Totally normal, in accessory mode it only draws from the 12v.
Actually, the DC-to-DC converter will come on to supply 12v power from the HVB in Accessory mode. It supplies a maintenance voltage, so it won't draw down your 12v. The indicator light will still show while in Accessory mode. Initially, the software set accessory mode to draw only from the 12V batteries, but that caused too many issues with dead batteries. Thank goodness they fixed it.
Jackdforme
A
Barry Allen: 2025 Ford F150 Lightning Flash
you sure about that? I ask because of all the battery issues (12v) on them.
Kansan
Wayne
2024 Flash
Civil Engineer
On my 24 Flash, accessory mode charges the 12v. The red battery indicator stays on in accessory mode even though it’s charging the 12v.
For "Those who got an update" the operation might now allow accessory mode LVB charging / maintenance ................ IF you got the update on "OLD" Lightnings or that it's baked into the newest model years.
I'd like to see proof by model year, with & without the modified software.
riggie
Chad
VT
2025 Ford F-150 Lightning Flash, Carbonized Gray, 9.6kw pro power onboard
tech
every car I've ever had (including Volt's, Mach E and now the Lightning) when in accessory mode the battery and some other lights as well, are all illuminated...normal
Jackdforme
A
Now I feel better in a mild climate, leaving it in accessory w/windows open. thanks.
