After the last update (window / door update) I noticed my doors locking on their own.
bryce
Bryce
2023 Lightning Lariat ER, 1999 Boxster
About $60 for the adapter and you can get a two month license for free. https://a.co/d/2orV0dZ Then a whole world of possibilities is opened.
My understanding is that it also requires a Windows PC. I just have a Mac. So that would increase my cost a bit. Perhaps there is one compatible with Chromebook? Will need to look more in to it.
Montecarlossfan
Connecticut
2023 Azure Gray XLT Lightning
Programmer
After the last update (window / door update) I noticed my doors locking on their own. Anyone else experiencing this?
Using phone as a key
22 Lariat, Ont Canada
I noticed this happened once today on my xlt…. Seemed to be an anomaly but it definitely locked on me as I walked away … I haven’t gotten it to happen again but it has never locked on its own as I walked away.
abcut973
Anthony
Denham Springs
Is that WAL requiring the PaaK or can it work with the keyfob only?
PJnc284
Garner, NC
It should work with just the fobs. Seem to recall reports of xlt and flash trims having wal but not paak
bryce
Bryce
Would you install a windows partition on your Mac and run a windows emulator?
That would be a possibility. However I did do that in the past on my iMac and I now have an unusable/unrecoverable partition on my HDD. Not sure if I want to torment myself or spend some money on an inexpensive PC laptop.
Truckdriver1880
Maverick, mustang
I’m in the same boat. Dealer did updates and now I have WAL but sync is not updated so no option to turn it off. Got the BC 1.4 update and hoped that would bring the option to the menus but nope. So now my truck locks itself all the time when in the garage and no one can put stuff in unless they remember the key. Very annoying!
Bokenator
Curtis
Georgia
2023 Lightning Lariat - Antimatter Blue. 2020 Hyundai Palisade Limited
Was washing mine and had it lock with the phone sitting in the driver's seat. Luckily I have the keypad and was able to get back in.
That was probably you just hitting the door handle sensor to lock with a wet sponge. I've activated the locks several times with this, especially if you are using warm water, although water straight out of the hose can do it too. My truck is constantly locking and unlocking when I wash it in the driveway. Maybe leaving it "running" would fix this?
mrau
23 Lariat⚡ER
I find leaving the key fob inside the truck prevents the constant lock/unlock when washing.
Sometimes I take the metal door key out of the fob and keep that in my pocket. Especially when using a wash far from home. ( Just in case I get locked out)
Bummer to hear that dealers don't do the Forscan changes. That seems like something they should do since I cannot make those changes without significant tech, and Ford does not seem to be able to enable their software updates to allow the functionality.
But perhaps the Sync updates will address the issue? I don't know enough about them but will rely on the collective knowledge of the Forum and its members. This place has been invaluable!
FORScan is hacking software, created by a person in Russia. It is NOT Ford-approved software, which is why dealers cannot use it.
Dealerships can update any module the vehicle has with Ford software, FDRS, an adapter, and a power supply. YOU can also do that. Adapter is like $500, power supply is like $200+, and the software is $50 for a 2 day subscription.
FDRS will NOT turn on any features that aren't supposed to be turned on. As an example, if you got the proper modules updated, you would have the CAPABILITY to turn on BlueCruise 1.4, yet no dealership can do that. But, after the modules were updated, you could then use FORScan to turn on the right switches to enable 1.4.
Windows only. Any machine that can run virtual Windows can also work to my knowledge, but I don't know that Chromebooks do that.
watts/up
23 Pro SR
Possibly related, but after receiving this update my passive lock buttons seem more responsive. I previously added passive entry to my truck and was bummed at how long those buttons sometimes took to lock the truck. They seem to respond faster now.
This could totally be my imagination though.
Well - I tested several times last night and no walk away locks for me even after the window update. '22 Lariat ER.
F150ROD
U.S. Navy Retired
Same. BCM update is needed.
bryansocko
Bryan
2023 Lightning Platinum
You absolutely need the BCM update for WAL. If you would look in Forscan and try to enable it the coding lines are not even present.
