EVO
Randy
Leavenworth, Kansas
2024 lightning flash
electrician
Tried to install 5.0 I get a SSH Authentication Failed. Under updater it says updates disabled SSH error. AJ can you save me again since apparently this areas server is broken.
Ajzride
Alan
Houston
Eng
Anthony is working on it right now, it is not specific to you at the moment.
Reactions: EVO
Ajzride
Alan
Houston
Eng
If you are Eric Meek and you submitted an order for a dock, please send me a DM, I can't reach you on email.
Ajzride
Alan
Houston
Eng
bp-5.0-beta should be back online for installs now.
mmarchand
Matt
F150 Lightning
I was able to get BP 5.0 installed yesterday. I was experiencing some ping pong on the highway and was hoping 5.0 would resolve this, but that doesn't seem to be the case. Is there a different model I should try or is there a specific setting I can slowly adjust to try to reduce?
Ajzride
Alan
Houston
Eng
How can we tell you to try a different model if we don’t know which one you are on?
mmarchand
Matt
F150 Lightning
Sorry, didn't know if there was one specifically meant for 5.0. It's just on the stock one that loaded with 5.0, Firehose
chriserx
Louisiana
there is one specific to 5.0, i don't know if it's locked or not, but as of yesterday there were no alternative models
mmarchand
Matt
F150 Lightning
Try filet o fish liquid crystal
That's the model I was on before upgrading to 5.0 and had the ping pong. Should I try that model on 5.0 and see if it's better or just jump to AJZ's suggestion of WD40?
UncleTony
Tony
2023 Lightning Lariat
Cybersecurity Engineer
You have to put it in offroad mode to change the model
PJnc284
Garner, NC
It just lets you adjust things that aren't available while the comma is active. Basically the same as if you plugged into your house.
