Stolibear
Jason
Wisconsin
2023 F150 Lightning
I am taking the plunge! Ordered a comma and q4 harness yesterday!!!!
I also went and submitted the form for the dock/coupler combo! (Keeping a close eye out for the payment email, hopefully you’re not out of stock!)
Ajzride
Alan
Houston
Eng
glad you posted, I had messed up the email address when I confirmed your order
DIEProphezeiung
Charlie
Birmingham
23 Lightning XLT ER
Hey all, I've had my 3x installed and running with no issues on my '23 XLT for the past year with no issues, until the past few weeks. I started getting a "Canbus disconnected. Likely faulty cable error" message on the comma sporadically, and the truck would throw camera and parking sensor errors at the same time. I could usually disconnect my comma (I have a 3D printer and printed a quick-disconnect mount similar to the one Ajzride has designed), then reconnect it, and it would usually come back up and work fine. But, recently, that has not been the case.
I have a Ford Q4 harness that I modified (cut and soldered in an extension). I assumed it was a bad solder joint because when I disconnected the comma, all the errors the truck was throwing went away.
I've taken the harness out, desoldered/resoldered all the connections I made with the extension, to no avail. I'm at my wits' end on this one. I'm not sure what to do at this point other than order a new harness and adapter to try it.
I have probed all the pins on the harness I have, and I have good continuity across all conductors, including the pairs with resistors to prevent start-up errors.
I have also tried swapping out all the USB cables from the harness box to the comma and eliminating all adapters to no avail.
I'm at a point now where the truck is throwing errors when the harness is plugged in, regardless of whether or not the comma is connected on the other end. The only thing I can think to try at this point is to order a new Q4 harness and the lightning coupler to try that combo.
Any help on this would be greatly appreciated.
Ajzride
Alan
Houston
Eng
What's the preferred driving model for 5.0? Not seeing it mentioned in the release notes unless I'm blind which is possible too.
There isn't one. 4.0 was the only one we did that for because there were so many issues with the default model. But I've had good luck running Cool People
Ajzride
Alan
Houston
Eng
It could be the actual harness box. Based on the time frame, you probably have the old style harness box with a mechanical relay. Honestly the best path forwards is to order a new Q4 harness kit and the coupler. This will get you the new style harness box which is solid state instead of mechanical, along with the automotive grade resistor coupler that Uncle Tony designed, which is far more robust and much more balanced for the system than the resistor design I initially made a video on installing.
DIEProphezeiung
Charlie
Birmingham
23 Lightning XLT ER
Ordered. I'll update here when they come in on whether it fixed the issue or not.
I didn't consider the harness box itself going out. Now I'm gonna pop that thing open when I get back home and start probing around.
chriserx
Louisiana
So, I've noticed it too, and from what it looks like to me is the Comma doesn't receive the truck off signal, when the truck is turned on again it gives the error, rebooting while in park seems to fix it, if not it throws another CAN bus error. This is just my experience so far and it's not definitive until I can find if and where they keep the communication logs on the comma.
DIEProphezeiung
Charlie
Birmingham
23 Lightning XLT ER
Interesting. I hadn't considered whether the power on/off sequence would make a difference. I don't have any particular consistency on how I connect/disconnect my comma. I always remove it from the mount and store it in the glovebox when the truck is parked. But while troubleshooting recently, I did try connecting it before powering on the truck and power cycling the comma while in park. None have helped with recent issues.
In the past, when I was able to power cycle the comma and have it come back working fine, I usually did so while driving.
chriserx
Louisiana
I literally just remote started my truck, walk out and could see the comma saying it was stopped for 300ish minutes, was going to take a pic for this thread, opened the door and it reset to 0 🤦🏻‍♂️
Ajzride
Alan
Houston
Eng
That is a known quirk with the stopped timer. It keeps track while the vehicle is off, even overnight.
chriserx
Louisiana
My suspicions of the CAN bus issue predates my use of the stop timer, you wouldnt happen to know where the logs are kept would you? All i've found so far is the video files and the car fingerprints to manually add the 2025 lightning. Any clues would be helpful.
UncleTony
Tony
2023 Lightning Lariat
Cybersecurity Engineer
Does the comma go offroad when the truck is turned off? Or does the road cam stay on the screen?
