chriserx
Louisiana
Sorry, didn't know if there was one specifically meant for 5.0. It's just on the stock one that loaded with 5.0, Firehose
there is one specific to 5.0, i don't know if it's locked or not, but as of yesterday there were no alternative models
EVO
Randy
2024 lightning flash
electrician
Try filet o fish liquid crystal
mmarchand
Matt
F150 Lightning
That's the model I was on before upgrading to 5.0 and had the ping pong. Should I try that model on 5.0 and see if it's better or just jump to AJZ's suggestion of WD40?
UncleTony
Tony
2023 Lightning Lariat
Cybersecurity Engineer
You have to put it in offroad mode to change the model
PJnc284
Garner, NC
It just lets you adjust things that aren't available while the comma is active. Basically the same as if you plugged into your house.
EVO
Randy
electrician
Its the model I use and have no ping pong. Every vehicle ,and driver are different so try them all except tomb raider. That one is not good on fords.
DIEProphezeiung
Charlie
Birmingham
23 Lightning XLT ER
Ordered. I'll update here when they come in on whether it fixed the issue or not.
I didn't consider the harness box itself going out. Now I'm gonna pop that thing open when I get back home and start probing around.
Okay, my new Comma harness has arrived, and even though I don't have the Lightning adapter yet, I've gone ahead and installed the harness and tried it with the USB cable that came with the new harness. It still doesn't work. I've gone ahead and tried eliminating points of failure again, and here's what I've found.
New harness with no USB plugged in = no truck errors
New harness + New USB = truck errors
New harness + New USB + Comma 3x = Truck errors and Canbus errors on Comma
New Harness + Old USB = no truck errors
New harness + Old USB + Comma 3x = Truck errors and Canbus errors on Comma
After inspecting the new, longer USB that came with the new harness, I've found a rather badly kinked spot, which could be causing the errors I'm seeing with the new cable. (pissed about that...) But even using the old shorter cable that seems not to throw errors without the comma plugged in, as soon as I plug in the comma, and even after waiting a while, the same old errors pop up on the truck and comma.
Other than waiting for the lightning adapter to come in, Ive tried all I can think of. im about ready to sell this damn comma and be done with it. At this point, it's a $1k paperweight.
chriserx
Louisiana
What software are you running, and are you sure you're at the right plug, there are at least 4 that fit the harness.
Edit: Without the adapter you are going to get truck errors. Without the lightning adapter, if you plug the comma harness in and leave the USB unplugged you should get no errors on the truck, then you plug the comma in and turn on the truck you should get errors on the truck.
Ajzride
Alan
Houston
Eng
This is normal until you get the coupler.
Reactions: EVO
EVO
Randy
electrician
Without the resistors,,"the adapter from tony" you will get errors.
darkameba
Zach
2022 F150 Lightning
Do you have the dock from @Ajzride? I can send you the dock integration version as a replacement so you dont have to use that male to male adapter.
Finally had time over the weekend to swap out the lightning adapter to the new one you sent. It was indeed the problem. Everything works perfectly now. Thank you so much for all of the help!
