Mike G
N. AL, USA
Released this morning 18 Sep 23.
Enables the free installation of an improved dash mat above the Sync screen to hopefully preclude spilled liquids from damaging the ACM (radio) module just below it.
All Lightnings made up to and including 22 Dec '22 are included in this CSP.
Owner letters will be sent the week of 2 Oct '23.
The CSP (funding and effectivity) expires on 30 Sep '24.
PV2EV
I am more concerned that I end up with rattles after the change...
PV2EV
Replacing one rubber mat...with another rubber mat...without the use of any tools. Where would you get a rattle from that process?
Oh, as the work estimate said half a day, I thought it was the entire dash pad, which might require dash removal.
I'm a bit confused. How is liquid going to leak through? Who uses that area as a cup holder?
That was my first thought. People do strange things though. I'm [sure there's] someone [who] had put a bowl of soup up there and took a corner too fast or something. I mean, they need to put warning on lawn mowers to not trim a hedge with it.
edited to make it clear that wasn't me :D
Yep, just showed up in my spanking new "Customer Satisfact.." icon in Ford Pass. :)
shutterbug
Joseph
Phoenix
I think the repair estimate says 0.2 hours. That's 12 minutes. Half a day estimate is how long it takes from the vehicle being accepted by the dealer until you can pick it up.
cal
Cal
Battle Ground WA
That's ridiculous. Something they could do while you wait.
Is the build date the one on the drivers pillar? Mine says 09/22 and I assume I've covered. I previously owned a car with multiple dates printed on stickers. One on the drivers sill and another on the pillar.
The GVWR rating sticker on the drivers door pillar is your Month/Year of manufacturing, while various parts will show a variety of productions dates as they are coming from jobber plants days/weeks prior the blend date.
Phineas Magliozzi
Bay Area
2023 Lightning XLT SR
Is that the same as the Blend Date on the Window Sticker? My truck is unavailable to compare, the dealer has had it for almost a month now...
I misspoke, it's the other sticker in the same area, in this example the pre-production model build truck was built December 2021 [12/21] at the bottom is the blend date of 12/06/2021 [120211206]
9920 is the production sequence number found on the top of your window sticker.
Ford F-150 Lightning CSP-23B11 -- Dash Mat Replacement (to prevent liquid entering through top of the instrument panel) 1695068076463
Maxx
I bet Ford lawyers edited the note and replaced “tighten the loose HV connection“ with “replace dash mat”.
If you are my age, there is a good chance that will happen but your truck will be fine.
