Were you watching it the whole time?Soc 6%
Charge time to 82% 1hr57min
The problem is not with the 350 they work great the problem is with 50kwh and 100kwhWere you watching it the whole time?
There is a ramp up and ramp down process, and the DCFC equipment might have issues delivering the requested amount, but at some point your truck would have been requesting between 150KW and 190KW +/- conditions like battery temperature.
POST #4 is the answer to the low capacity DCFC systemsThe problem is not with the 350 they work great the problem is with 50kwh and 100kwh
I only ever get 40-45kwh And 80-90kwh
Which on 50 mean 2 hrs waiting any way hopefully there new charger coming to this high way
People ???98kwh battery it just is a bummer when or people can charger faster at the same charger and it’s a 50kwh
increased SOC by 76% of 98 KWH is approximately 74.48 KWH of energy to battery, gross energy is probably closer to 82 KWH, the receipt for the session will tell you how much was consumed.Soc 6%
Depends on the charger and ambient temp. Not all dcfc are the same.Why will ford not accept the full 50 kWh
My truck charges at 40kwh and after 1hr it reaches 45 maybe and other cars can get 47-49kwh
350kwh chargers it goes straight to max the truck can expect ?
Soc 6%.
1hr57min 82%
Very true! I charged over the weekend at a 50 KW charger and ran a steady 45 KW charge rate from 44% to 59%.Not all dcfc are the same.
Don't forget the mid range 123kWh pack.BTW, what year is your Lightning?
Is it an extended range 131 KWH or standard range 98 KWH battery?
Asking these details to help analyze post #3 values.
