jwrezz
Following. I know I have used OPD since I got the truck 3 weeks ago. Very interesting conversation. I may have to try the different modes.
While not incorrect, it could also be misunderstood.In short:
The Lightning’s brake lights illuminate any time the deceleration exceeds a set threshold, whether that’s caused by regen, friction brakes, or a mix of both.
You have been proved wrong on this so many times now I think YOU need to test it. I know that I HAVE tested it, we have even shown you the video evidence OF it being tested, I MADE those videos.the truth is not always what you assume.... TEST IT.
ChatGPT 5 surprised me because it's usually wrong but I actually think this is the correct answer. Who knows, maybe some intern at Ford copied the actual technical document into ChatGPT to get a summary of it and now it's part of its training data
In 1-Pedal Drive mode, the Lightning primarily uses regenerative braking to slow the truck down. That means the electric motors act as generators, converting kinetic energy back into electricity and sending it to the battery.
However:
- If you demand more deceleration than regen alone can provide (for example, in a hard stop, steep downhill, or when the battery is near full and can’t accept much charge), the truck blends in the physical friction brakes automatically.
- At very low speeds, regen effectiveness tapers off, so the Lightning uses friction brakes to bring the vehicle to a complete stop and hold it there.
- The handoff between regen and friction is seamless — the driver doesn’t feel a sudden transition.
So, short answer:
In most normal slowing and stopping, the Lightning relies almost entirely on regen in 1-pedal mode.
But yes, it will use the friction brakes when regen isn’t enough or at very low speeds.
On the F-150 Lightning (and most EVs with one-pedal driving), the brake lights aren’t tied only to the physical brake pedal — they’re controlled by deceleration level.
Here’s how it works:
This is done so that drivers behind you can anticipate your slowing, regardless of whether it’s regen or friction braking causing it.
- When you lift off the accelerator in 1-Pedal Drive, the truck starts slowing with regenerative braking.
- If the rate of deceleration is high enough (roughly similar to what would happen if you pressed the brake pedal lightly), the brake lights automatically come on — even if you never touch the brake pedal.
- If the regen is very gentle (like easing off on the highway), the brake lights may stay off.
- At very low speeds, when regen blends into friction braking to bring the truck to a stop, the brake lights remain illuminated until you accelerate again.
In short:
It still IS wrong lol. I posted above that the brake lights come on immediately in 1PD mode just barely lifting my foot partially off the pedal. When I say immediately, I mean instantly, right now, no waiting. Not even enough regen working to slow the truck and the brake lights came on.ChatGPT 5 surprised me because it's usually wrong
Exactly my experience as well.There is one caveat to this. It does not illuminated the brake light in two pedal drive mode, even in Sport. Typically it wouldn't deceleration hard enough for it to be an issue but I have tested this going downhill with cruise set at a lower speed and suddenly releasing the accelerator. The deceleration rate should well exceed the brake light threshold but it does not and the lights do not illuminate.
At this point I suppose we're splitting hairs, but at least on mine it's definitely not "immediately" or "barely lifting"It still IS wrong lol. I posted above that the brake lights come on immediately in 1PD mode just barely lifting my foot partially off the pedal. When I say immediately, I mean instantly, right now, no waiting. Not even enough regen working to slow the truck and the brake lights came on.
I wrote this in post #7. It's still true. I'll even go out on a limb and say Lightning brake lights come on at a deceleration rate of 1.3m/s2 or brake pedal application since they sell EVs in Europe and it would be an enormous waste of money to develop two standards.The brake lights come on at a certain deceleration rate (1.3m/s2 in EU, manufacturer choice in US) or brake pedal application. If you aren't pressing the brake pedal there isn't a reliable way to determine if friction brakes are in use.
They may have changed operating strategy between your 22 and my 25, all I can do is report what I'm experiencing.At this point I suppose we're splitting hairs, but at least on mine it's definitely not "immediately" or "barely lifting"
I can easily slow down at a stop light without the brakelights coming on until the very end, maybe from 45 to 15 without and 15-0 with brake lights and that at a rate you can feel in your body, around 1/2" green on the acc/dec meter.
It gets more sensitive the slower you go, so yes, at 10mph I'd agree with "barely" but at 45+ you can definitely feel it.....
Not in my case, perhaps they changed parameters between the 22 and 25 year models.I wrote this in post #7. It's still true. I'll even go out on a limb and say Lightning brake lights come on at a deceleration rate of 1.3m/s2 or brake pedal application since they sell EVs in Europe and it would be an enormous waste of money to develop two standards.
Carscanner has a PID for brake line pressure. I verified that 1pd drive does not use friction brakes, not until the last 1mph or so to come to a complete stop.The brake lights come on at a certain deceleration rate (1.3m/s2 in EU, manufacturer choice in US) or brake pedal application. If you aren't pressing the brake pedal there isn't a reliable way to determine if friction brakes are in use.
Everyone else would be confused if the term "negative acceleration" was used.I'm just hoping there aren't any physics professors around...because this thread would get real heated with the term "deceleration" being thrown around...
What about acceleration in the opposite direction?Everyone else would be confused if the term "negative acceleration" was used.
