Status
Not open for further replies.
Bob_Mac
Bob
North Carolina
2021 Ford F-150 Platinum
Cyber Security | Developer
I'm not convinced it's a J2534 issue per say but an FDRS issue in general.
tonesto7
Anthony
2021 Lariat 502A | 3.5L EB
IT Admin | Software Developer
I agree... I looked at the FRDS logs and it indicated in my opinion so sort of conversion issue with FRDS
BHunted1
Sumner County TN
2021 Ford-150 Platinum Hybrid
Just want to throw this out there for folks going google-eyed trying to compare ab files. I use a free program called Winmerge.
I download my ab data files and rename to an xml file. I also insert the date after the vin in the name: ###_022422.ab.xml - This is just easier so you can see which file is in which side by side panel in Winmerge.
I save them to just a folder called AB where I keep my fdrs data.
Open Winmerge> open file. You'll see a window pop up where you can compare 3 files. I just do the last 2 ab files I downloaded. Use the Prettify xml below and hit compare. Easy to read your ab files. Either scroll through all the highlighted lines or use the search field to get you where you want to go.
Hope that helps. Saves my eyes for sure.
Bob_Mac
Bob
North Carolina
Maybe but Jesse’s VCM II is not showing these issues.
When did he post that? FDRS had an issue with 31.6.2 and came out with an updated one 31.6.4 in less than a week due to the .2 version causing corruption issues...
Bob_Mac
Bob
North Carolina
I'm seeing the same issue in my as-built data. @tonesto7, please keep us updated on how you resolve. Thanks!
What device are you using to connect, i.e. VCX Nano, Mongoose, etc.? We're trying to put all the pieces together to see if we can resolve or have to wait on Ford for an updated FDRS.
BlackSheep
Indiana
2021 F150 Powerboost
I used the VCX Nano to update my truck.
JEB
Northern Illinois
2021 F-150 Lariat Powerboost
It was a PM.
EDIT: It was also posted earlier and it might have been been a VCM3. See post 300.
Lodans
Austin, Texas
2021 F150 Powerboost King Ranch
Building Automation
I'm in the same boat. VCX nano
<NODEID>
712
<F110>DSMU5T-14F548-DB</F110>
<F111>MU5T-14G009-DC</F111>
<F113>MU5 T-14F548-DD</F113>
<F129>MU5 T-14G009-EA</F129>
<F159>030000</F159>
<F15C>051103</F15C>
<F15E>030804</F15E>
<F160>062500</F160>
<F161>021906</F161>
<F188>MU5T-14G003-DD</F188>
<F18C>2010</F18C>
</NODEID>
<NODEID>
7D0
<F10A>MU5T-14G680-AA</F10A>
<F110>DSMU5T-14G670-EG</F110>
<F111>MU5T-14G681-KF</F111>
<F113>MU5T-14G670-PNL</F113>
<F124>MU5T-14G677-ABA</F124>
<F129>ML3T-14G00T-18K811-AA</F129>
<F12A>ML3T-</F12A>
<F12B>ML3T-18B955-BE</F12B>
<F12C>FFF1-14F180-FE</F12C>
<F142>MLBE10218S</F142>
<F143>20210224041110</F143>
<F144>R3W9QDWA</F144>
<F16B>MU5T-14J003-AF</F16B>
<F17F>1SN12C11</F17F>
<F188>MU5T-14G676-EG</F188>
<F18C>FUBCH20346051212</F18C>
<F190>Vin Number</F190>
<F1D0>28385C047D1D</F1D0>
<F1D1>28385C047D1E</F1D1>
</NODEID>
iceman77
Pete
2022 Ford F-150 Platinum
<NODEID>
712
<F159>030000</F159>
<F15C>051103</F15C>
<F15E>030804</F15E>
<F160>062500</F160>
<F161>021906</F161>
<F18C>2010</F18C>
</NODEID>
<NODEID>
7D0
<F12A>ML3T-</F12A>
</NODEID>
The 712 (SCMG module) field F113, F129 are certainly Network Scan related corruptions. The 7D0 (APIM module) is not. I have see the F12A field like above on trucks that posted self-report and no network scan has been performed for a while (or at all)
tonesto7
Anthony
If that's true then my UCDS adapter does not have the same J2534 passthrough corruption that occurs with the VCX Nanos
iceman77
Pete
Jesse uses VCM3 device and this device is not J2534 pass-through device. It uses J1708 and J1939 protocols instead
iceman77
Pete
Could be VCX Nano firmware bug, could be just baud settings or similar. I did not play with it. I will buy the Mongoose-Plus cable when I get my truck back, test it out and report my results here
iceman77
Pete
Also, I would wonder how is your UCDS adapter recognized by FDRS. Is it indeed J2534 pass-through device, or perhaps this device supports other protocols (such as J1708 and J1939 as VCM3) ?
Status
