Status
Not open for further replies.
JEB
Northern Illinois
2021 F-150 Lariat Powerboost
Jesse uses VCM3 device and this device is not J2534 pass-through device. It uses J1708 and J1939 protocols instead
RIght. I remember now. The point I was making to Bob_Mac was that because not all programmers are creating corruptions, it remains unclear whether it is an FDRS problem, generally, a problem with the the use of J2534 with FDRS, or the use of the Nano in particular. Since the VCM3 seems to work without issue, it isn’t FDRS, generally. And your testing of the Mongoose should further narrow it down to either J2534 or the Nano.
tonesto7
Anthony
2021 Lariat 502A | 3.5L EB
IT Admin | Software Developer
Also, I would wonder how is your UCDS adapter recognized by FDRS. Is it indeed J2534 pass-through device, or perhaps this device supports other protocols (such as J1708 and J1939 as VCM3) ?
it shows up as a J2534. "UCDS-J2534"
JEB
Northern Illinois
It was late when I thought I read this, but didn’t you say that you were seeing corruptions with the UCDS? If that’s so, that seems to add credence to the theory that using J2534 with FDRS is the problem right now. It’s not a Nano-specific bug.
iceman77
Pete
2022 Ford F-150 Platinum
His AB data looks solid, either though I recall his APIM reporting values such as FFF1-14F180-FE and I see this in his current AB as well. Not sure if this is part of J2545 NetworkScan corruption or something else
JEB
Northern Illinois
I’ll be glad when you’ve had a chance to test the Mongoose.
There is definitely something odd happening with the APIM. I have logged into FDRS a couple of times today—cloud only, no network scan. Sometimes the software version is populated immediately after the vehicle ID, sometimes it isn’t. As I mentioned above, the FDRS team has said that it is aware of issues with vehicle ID in Sync 4-equipped vehicles and are working on it.
antho
Anthony
Houston, Texas
2021 801A Raptor
This isnt actually effecting the modules but just the data sent back to ford from FDRS? Once the modules report their data ota that will fix the issue we are seeing in Fords reported data?
Bob_Mac
Bob
North Carolina
2021 Ford F-150 Platinum
Cyber Security | Developer
Hence why I'm sticking to an FDRS issue but, time will tell. I just checked again (cloud only) and the APIM & TCU both show issues.
Bob_Mac
Bob
North Carolina
I don't think it's affecting the modules but, the AsBuilt shows the same issues and would probably prevent any OTA's being pushed to us due to the corruption.
antho
Anthony
Houston, Texas
2021 801A Raptor
Thats what i was thinking. If Ford doesnt see the proper module info, It probably wont sent out an update for it.
Bob_Mac
Bob
North Carolina
Off Topic: Question for everyone, does anyone know what the 'ACM - Sound System Upgrade' does in the Programmable Features tab?
JEB
Northern Illinois
That was something I was thinking about as well. Has anyone who performed a manual module update gotten an OTA (any OTA) after the update? I haven’t and I know 2.4.1 came out well after my first tour through FDRS in January.
speedracercjr
Cory
Houston
2021 Lariat EB
O&G
Don't suppose this corruption would also be causing the restart loop with a USB drive by chance?
Jesse-Infotainment
Jesse
2024 F150 Lightning Platinum
Amazing how far everyone has come.
JEB
Northern Illinois
@iceman77 gave a good explanation of what is going on at Post 300. Reading it again did quite a bit to calm my nerves.
Status
