Status
Not open for further replies.
iceman77
Pete
Dallas
2022 Ford F-150 Platinum
From my observations, for OTA to work, F188 (STRAGETY) field must be intact. Especially on GWM.
Other fields such as F124 (CALIBRATION) and F10A (ECU_CONFIGURATION) might play a crucial role as well, but it is unconfirmed at this time.
iceman77
Pete
Dallas
Can you elaborate on this request?
You can publicly download AB data for any truck here. Data in this file is a minimized (unformatted) XML, with fields coded as "Fxxx", unreadable at first glance. It is PIA to modify this file to a readable format each time you download it and use a cheatsheet to determine what each "F" field means. Would be nice to have a tool that would automatically convert this file into a more readable format.
iceman77
Pete
Dallas
Thanks for confirming. Hopefully, someone finds a fix soon.
No need for a fix. Your truck will send its own version of "network scan" that will correct all issues you see currently in your AB file. All you need to pay attention that your GWM data are in good shape
BHunted1
Sumner County TN
2021 Ford-150 Platinum Hybrid
I posted it above: Winmerge works great. Compares the files too and highlights differences.
ECU module programming guide using FDRS | Page 43 | F150gen14.com -- 2021+ Ford F-150, Lightning EV, Raptor Forum (14th Gen) | Owners, News, Discussions
Ford F-150 Lightning ECU module programming guide using FDRS wm
nicholsbradley
Bradley
Louisiana
2021 Ford F150 Platinum
Analyst
Took my truck to dealership today for some recalls and said hey can you catch me up on all the updates "FDRS". They stated they only do updates if something is wrong. I mean wow, how can it update itself if its so far behind on everything. Ford services has gone to shit.
tonesto7
Anthony
2021 Lariat 502A | 3.5L EB
IT Admin | Software Developer
Here is detailed breakdown of AB fields for APIM:
XML:
<NODEID>
   7D0
   <F10A>MU5T-14G680-AA</F10A>
   <F110>DSMU5T-14G670-EG</F110>
   <F111>MU5T-14G681-KF</F111>
   <F113>MU5T-14G670-PNL</F113>
   <F124>MU5T-14G677-ABA</F124>
   <F129>ML3T-18K811-AA</F129>
   <F12B>ML3T-18B955-BE</F12B>
   <F12C>FFF1-14F180-FE</F12C>
   <F142>MLBE04324F</F142>
   <F143>20201102212414</F143>
   <F144>AKC0NDHG</F144>
   <F16B>MU5T-14J003-AF</F16B>
   <F17F>1SN11346</F17F>
   <F188>MU5T-14G676-EG</F188>
   <F18C>FUBCH20333050605</F18C>
   <F190>1FTFW1E85MFAxxxxx</F190>
</NODEID>
Code:
F10A        ECU_CONFIGURATION
F110        PART_II_SPECIFICATION (ASSEMBLY)
F111        CORE_ASSEMBLY_PART
F113        ASSEMBLY
F124        CALIBRATION
F129        OTHER
F12B        OTHER
F12C        OTHER
F142        SERIAL_NUMBER
F143        SERIAL_NUMBER
F144        SERIAL_NUMBER
F16B        ECU_CONFIGURATION
F17F        SERIAL_NUMBER
F188        STRATEGY (SW VERSION)
F18C        SERIAL_NUMBER
F190        VIN
Looking closer at the F12C (OTHER) field, my old truck self-reported FFF1-14F180-FE. This might be either a valid value or a result of something else as Network Scan via J2534 pass-through in FDRS. So, @tonesto7, you are in my opition in good shape as far as AB data integrity on Ford servers
Thanks for that... I had the address breakdown at one time but lost it.
tonesto7
Anthony
I seriously want to build a whole platform that allows us to decipher all of the asbuilt and modules.
I want a web portal that will show us which asbuilt options are available for our vehicle and firmware.
I was going to start with creating a web-based version of using Livinitups spreadsheet and allowing descriptions and more.
There are just so many variables that need to be considered to make something like these useful and maintainable. I will definitely need multiple in on a project like this.
In the meantime, I think I can make an electron app that does what you are asking. I just need some time to finish up some projects that I'm working on
RellIk&5
Wayne
Las Vegas, NV
2021 F150 XLT Black Widow
Does anyone have any errors toward the bottom of their AB file? I downloaded mine from the Motorcraft site and have this as the very bottom:
<ERROR>
<ERRORCODE>612</ERRORCODE>
<ERRORMSG>PCM DATA NOT FOUND</ERRORMSG>
</ERROR>
<ERROR>
<ERRORCODE>614</ERRORCODE>
<ERRORMSG>CCC DATA NOT FOUND</ERRORMSG>
</ERROR>
BlackSheep
Indiana
2021 F150 Powerboost
Thanks for that info! I was concerned. Appreciate all you have done in this thread!
Bob_Mac
Bob
North Carolina
2021 Ford F-150 Platinum
Cyber Security | Developer
Here's a complete breakdown of fields you see in As-Built dataset for the GWM module:
XML:
<NODEID>
   716
   <F10A>ML3T-14J009-EKB</F10A>
   <F110>DSMU5T-14G650-ED</F110>
   <F111>MU5T-14H026-AH</F111>
   <F113>MU5T-14G650-ABX</F113>
   <F16C>ML3T-14J007-EKB</F16C>
   <F17F>1EG110L5</F17F>
   <F188>ML3T-14H021-EKB</F188>
   <F18C>FUBCH20339031102</F18C>
</NODEID>
Code:
F113        ASSEMBLY
F16C        ECU_CONFIGURATION
F17F        SERIAL_NUMBER
F18C        SERIAL_NUMBER
F190        VIN
When you skip FDRS NetworkScan and you opt for "cloud" based vehicle info download, that info is stored in JSON format here:
C:\ProgramData\Ford Motor Company\FDRS\fdrs\data\vehicle\{your_vin}_en_US.json
It contains all your vehicle information, including module version, configuration as well as your AB data. You can use this file to figure out what different "F" fields mean.
Thx for this!
iceman77
Pete
Dallas
<ERROR>
</ERROR>
<ERROR>
</ERROR>
My old Job 1 truck has the same error code so does my new 22 F-150. I would not worry about those much though.
22Platinum
Washington dc
2022 F150 (on order), 2003 Lincoln Town car
software engineer
Where does the cheatsheet come from?
iceman77
Pete
Dallas
I just shared them here and here. I created them (only for GWM and APIM) based on the vehicle info JSON file downloaded by FDRS tool from cloud. I have shared the location of the JSON file here.
nicholsbradley
Bradley
Louisiana
Analyst
So guys my dealer refuses to do any updates if no issues are errors in truck. No matter how far behind. How hard is the update process and have any improvements been seen doing this?
Status
