Status
Not open for further replies.
Ebrou
Mobile, AL
2021 F150 XLT SCREW 5.0L Sport 4x4
TJSparky
WA
2021 F150 XLT (302A) RockyRidge K2
Thank you, I'll check it out and compare the IPC info to what you posted
I'll run a few hundred miles and see if the adaptive table reset I performed improves and if not, I'll take to the dealer to perform service
I tried that and it didn't work. The break-in procedure really helped the transmission shift better. Its all done via FDRS (i believe) but I think the vehicle needs to be on a Frame Lift to do the procedure.
What is your F188 Strategy version at after the IPC update?
RapidRedRick
Northern Virginia
Ford F150 Platinum Powerboost
Sounds like you had a BCM update that may not have been completed correctly or got corrupted. PM me your VIN and I'll look at your AsBuilt data.
@Bob_Mac, started
@Bob_Mac, I used the conversations functionality to send you my VIN. Kinda new at this, is that what you meant by PM?
Bob_Mac
Bob
North Carolina
2021 Ford F-150 Platinum
Cyber Security | Developer
@Bob_Mac, started
Ok, the BCM update looks like it failed as I see corruption in your AsBuilt. Tagging @Jesse-Infotainment to see if he can look on his end. PM him your VIN and when he has the time I'm sure he'll help out.
Jesse-Infotainment
Jesse
Dallas
2024 F150 Lightning Platinum
I just saw the tag. I’ll take a look in depth at the logs and see what happened.
Bob_Mac
Bob
North Carolina
Got my Mongoose adapter in today. I uninstalled everything that was related to the VCX NANO, installed the Mongoose then ran FRDS via cloud and as luck would have it, I have another APIM update! I will be doing this tomorrow and will report back how things went.
iceman77
Pete
Dallas
2022 Ford F-150 Platinum
Can you confirm if network scan run via FDRS causes any issue with the Mongoose+ adapter ?
Bob_Mac
Bob
North Carolina
I will be doing that after I do the APIM update. I want to make sure that the update completes, then check the AsBuilt data and if all good with the APIM then restart FDRS and do a network scan...
antho
Anthony
Houston, Texas
2021 801A Raptor
@Bob_Mac
Awesome. Please let us know. I’m about to throw this VXDiag Nano crap in the cul de sac and run it over.
JScaro
Georgia
2021 Ford F150 Lariat
Beer Drinker
Let us know how the Mongoose works compared to the VCX Nano, wonder if it's work the extra $300.
Did you get the SS USB?
Bob_Mac
Bob
North Carolina
@Bob_Mac
I already have a return prepared by Amazon.
Status
