Error in programmed charging
htobin
Howard
Ovalo TX
F150 Lightning 2023 Lariat
My programmed charging is to 85%. Last night when I plugged into my home charger, the charging began normally. However, this morning it had only charged to 55%. and charging had ceased. Additionally, when I looked at my charging history on my iPhone, there was no record of the charge. Any ideas or suggestions?
Grumpy2
Central Oregon Coast
23 F150 Pro SR
Retired Hvy Construction
Did you check your "one time" charge limit? Perhaps the button had been touched previously...
Usually when we encounter malfunctioning schemes, the first solution is to delete it and construct a new one.
htobin
htobin
Howard
Ovalo TX
Do you do that in the truck or on the Ap?
There won't be any record of the charge until you unplug...
htobin
htobin
Howard
Ovalo TX
You're right. The charge did later show up, but for some reason, it stopped at 1:57 AM. I'll give it another try before changing anything. Thanks to all for the help. What a great source of help and knowledge.
invertedspear
AZ, USA
lightningcalcs.pages.dev
What kind of charger do you have at home? When I was using the trash Ford mobile charger, the heat of summer would cause it to shut down and stop charging in the middle of the night. When I switched to a wall mounted charger, I never had another issue like that.
htobin
htobin
Howard
Ovalo TX
I have the Ford supplied charger running on 220 volts. It's worked fine up till this one error
