EV motor maintenance? Gear fluid change? When?
21st Century Truck
Martin
A non-engineer here whose Mach E front motor did fail, catastrophically (see post #4 here) and whose next, warrantied front motor was about to fail when I traded the car... as well as the youngest brother of three, the others both engineers who never, ever let me forget it :crackup:
IMHO this is a question of relative risk. Yes, OEM testing parameters establish reasonable intervals for X, Y and for Z. Yes, IMHO there is no harm in changing oils etc. earlier as long as it is done carefully, with good workmanship and to standards, which is BTW why many of us prefer to DIY these things, as we are sure to do it right and not depend on the unseen back-of-shop 20 year old who might be working to time and not to standards of carefulness, and who might be thinking of his date tonight rather than about the potential to mis-thread something. I once was that 20-year old... just sayin'.
Anyone ever watch thru the open bay doors as the wheel / tire guy grabs that pneumatic tool and goes UGGA - DUGGA on the wheel lugs, instead of even thinking about how to set a torque wrench to a manufacturer's torque setting?
On the other hand, these EV motors on our Lightnings are not easy to get to for example the motor refilling plug up on the side.
My Mach E's front motors were made by Borg - Warner, a company with a long history of good manufacturing. Yet, they both failed, both within warranty... and the 1st failure was absolutely a failure of its internal seals. Cause = unknown to me, of course, so it could have been heat effect, or it could have perhaps been the effect of my installation of German high-end coilover sets which might (??) have slightly changed the half-axle entrance angle within the motors long enough to...??
I write this because, with 76,000 miles on our Lightning now I am weighing having their Mercon fluid (and any filter) changed in both motors. Cost vs. inconvenience vs. relative risk, right?
A key point I learned with the Mach E front motor failure(s): once a motor is changed out under Ford warranty, this particular new assembly's warranty then runs for only the next 12 months, no matter the age of the car or its mileage or its original warranty for the rest of the car. And the warranty cost the dealership charged Ford Corporate for the new motor and labor was a shade over $5,000 (I saw the warranty bill to Ford Corporate... I'm at a good dealership and they work with me).
Athrun88
Toronto, Ontario, Canada
Just for the record, as a non-engineer-trades-trained-DIYer, if something is a sealed system, I am just smart enough to not mess with it. To me, sealed = replace the whole thing; however, if there are ports, inlet, outlet, discharge functions, I will explore the DIY route because it was designed for it. I never think of myself as smarter than the actual engineers who designed these things. I am, and I'm sure most of us here, are also smart enough to determine what should/could be DIYed and what should/must be left to the shop for liability purposes :p
RLXXI
3rd rock
Automotive Technician
A differential in an ICE truck runs at 200 degrees?
Internal Combustion Engine runs at 200. Differential maintenance is 100,000 miles for most.
It's the engine heat that does the premature breakdown of fluids. The electric motor does NOT get any where close to an ICEngine temperature.
Karlos
Karl
DFW & Kerrville Tx
Retired CPA, active pilot
Would be interesting to see a filter cut open & pleats inspected for particulate matter, fluid condition etc. Would make an informed decision easier for the next maintenance interval.
WXman
Central Kentucky
2025 F-150 Lightning Flash
Meteorology/Transportation
I think we've got two totally different tracks running trains of thought in this thread.
How did engines ever get brought into this discussion? OP was talking about GEAR OIL. So then the conversation turned to maintenance intervals for ICE GEAR OIL vs. EV GEAR OIL. I don't know how engines came into the discussion. :crazy:
So again, engine heat has little to nothing to do with gear oil temperature on an ICE truck. And therefore the gear oil should stay much cooler than the gear oil on an EV, and therefore the idea (which was presented earlier in this thread) that EV gear oil should last longer than ICE gear oil is probably wrong. It's likely just the opposite.
RLXXI
3rd rock
3 trains of thought. Some one else was arguing about longevity and heat.
I'm in the let it ride as per the manual and change it at 150k miles as the heat is not a factor.
Firn
23 Pro ER
You were the one who made it about differentials.
Prior to that the discussion mentioned transmissions and motors, not differentials.
RLXXI
3rd rock
Ok then, apparently the cooling system on these trucks run about 104°f depending on load and ambient temperature. Heater part of the system gets up around 158°f.
Another thing to note is both motors have oil coolers to further decrease heat breaking down the oil.
This is why the oil lasts longer making servicing few and far between.
