FCSP Software Version 2.500.34-ford.27+26-08
Aminorjourney
Nikki
Internet
www.transportevolved.com
I don't want to pre-empt this, but I think I've found an actual bug in the codebase that could be causing the issue that I and other people have experienced. However, I want Ford to look at it to confirm.
Also, I can see at least *one* of my charging stations has the download waiting to take, so... I'll see what happens ;)
Aminorjourney
Nikki
Internet
So…
It’s 3:55 am. And a MASSIVE storm just came through and woke me up.
My outdoor unit is now displaying the same issues that everyone else has experienced, and I need to wake up and have coffee before I do more digging.
It looks as if I still have root access which is good…. But here’s the weird thing.
We had a massive thunder clap and the power went out. Then, about 30 seconds later, the power came back on. FROM THE TRUCK.
This has legitimately never happened before. I don’t know it was the update, the fixes I applied to address the logging bug or something else. I need coffee and time to figure that out…
We had some big storms come through overnight Wed. I don't know if we had a power surge that may have reset the FCSP, but when I plugged in yesterday, it immediately started charging at 60A (which I had set on Tues). So I guess the change did eventually make it through, it just took a long time or a possible reset. Storm chances drop over the weekend so I can play with the setting a little more reliably. Thus far, I can still see charge sessions on the Insight page (still showing up after I unplug), but still cannot connect via setup app to see version numbers.
K6CCC
Glendora, Calif.
No storms here, but I just checked and confirmed that the Charge Station app can see, but not connect to my FCSP - no change. As a test, I just used Ford App > Charging > Charge Station > Settings > Max Charge Current set to 36 amps (instead of my normal 48). When going back into that setting later, the change is shown. I'll see what charge rate I actually get tonight. Tonight will be a good night for it as I will only need about a 40KWH charge.
