*Fixed!* - Urgent! NO INSTRUMENT PANEL!
MichaelCA
Even if it is, I don’t really want to find out the hard way that it needs replacing.
Mine turns 2 soon and I’m searching for lithium options, absent of any I’ll go AGM with mine. I haven’t found many yet, just this one so far from a brand I’ve never heard of. (*Note: The teardowns show this particular battery is NOT a good quality with potential safety concerns)
Interesting video, I saw alot of discussion people buying Ohmmu batteries. I think EarthX is floating around as a candidate for lithium battery. I do see a thread on the tesla forums about a person having issues with EarthX too though.
Yellow Buddy
Mid-Atlantic
Smart Ass
That’s the common problem with a lot of these lithiums unfortunately…
Bokenator
Curtis
Georgia
2023 Lightning Lariat - Antimatter Blue. 2020 Hyundai Palisade Limited
back to the OP topic, I had my dashboard do the same thing on two consecutive starts back on November 21st of 2023. Going to lunch, and 45 minutes later coming back from lunch. Here is my dash:
Ford F-150 Lightning *Fixed!* - Urgent! NO INSTRUMENT PANEL! 1703775858822
I happened to be taking the truck in for recall work (tailgate lightbar) and CSP (heated steering wheel upgrade) the following Monday, and had an open correspondence with Ford Motor Company via this forum at the time, so they checked it out while they had the truck. They couldn't reproduce it and seemed to write it off as a 1-day glitch. It hadn't happened since.
Just FYI, I was able to maintain speed awareness via Waze thru Apple CarPlay.
Good to know that the solution is simply unplugging the negative battery terminal.
rtk11226
Rusty
Houston Area,Tx
2023 Ford Lightning/1991 Chev 1500/1976 Corvette
Retired IT/Engineer
Lightning Rod
North Coast
2023 Ford Lightning Lariat ER
CNC PROGRAMMER/MACHINIST
Glad you waited until getting home, no telling why this happened, but if you had just come out of an update that processes without a prolonged downtime, it might have been an after effect of an update, what was your most recent OTA, 6.5, 6.8, 6.13??????
I'm planning to replace the OEM LVB with a higher capacity unit next summer when my truck turns two.
I have an XS Titan Power Lithium Ion Battery RSV-S5, wired in parallel with my OEM battery to assist my 12v system. I have several audio amplifiers and so far, the truck seems to be ok with the addition. I added it in August.
Ford F-150 Lightning *Fixed!* - Urgent! NO INSTRUMENT PANEL! ExtraLVB
Ford F-150 Lightning *Fixed!* - Urgent! NO INSTRUMENT PANEL! RSV-S5-turn
LifeAsDane
LifeAsDane
Dane
SW Florida
22' Lightning SR Lariat | 13' F150 EB Lariat
Real Estate
Not to hijack the thread, but I didn't realize that the battery only had a 24 month warranty on it. I guess since mine is a 22, I will be replacing it next year.
I would expect it to still be covered under your Ford warranty even after 24mo. I'll also add this 12v was already replaced about 3months ago when my truck started failing to update OTA. Ford replaced it and forced update to get it to start working again.
Lytning
Georgia
Half-size battery, half-size power, half-size warranty.
Grease Lightning
Johnathan
Albany, Oregon USA
2023 F-150 Lightning XLT
Mine did this today too. Died several restarts and nothing. Took it to the dealer and scheduled an appointment and it worked when driving away.
Just needed to show the lightning it needed to be nice or I would make it go back to Ford??
Mike G
N. AL, USA
Yes, I've read that, and also that AGM-based lead acid batteries withstand deep discharge better than classic lead acid batteries. I just wonder why Ford is so stingy about keeping the LVB charged up. It will happen all the time if one's driving. Why not have it happen all the time if the vehicle is plugged into a charger; if necessary, when the HVB isn't charging? So, my worry was if the vehicle's mainly designed always to be charging when it's turned "on," am I doing something different that's not so good when I'm charging it all the time in full-accessory mode with the cooling not running for the HVB (and the engines), etc. Ignorance leads to uncertainty, which leads to (needless) worry. Ford clearly recognizes the problem with EVs in storage or little driven but they don't have a "no-brainer" solution, IMHO. This 2020 article, before the Lightning, by a Ford battery expert, is more direct than our owner's manual on addressing the importance of keeping the LVB charged up: How to Self-Isolate Your Electrified Vehicle | Ford Media Center
Improved 12V battery management should be coming in the near future for the Lightning. Some MMEs have already gotten this update (the MME version was 23-PU1024-MCP-FX). It will show as a powertrain update.
mf25053
2024 Lightning Flash
Automotive infotainment
Time to pull the negative 12V battery terminal. Wait at least a minute and reconnect.
My hat is off to you. This just happened to me tonight, and sure enough pulling the battery worked like a charm.
Had to sign up to say thank you, and hopefully learn some more along the way.
data003
Maine
The Lightning should come with a 10mm wrench in the glovebox ?
Seems like 90% of the time disconnecting the 12V fixes the odd electrical issues.
