I do have the Forscan changes to enable PPOB with the truck off. 2022 Pro (also in the program that rhymes with shmirly shmaccess)Question for all members running 6.2.0 and seeing the PPOB controls..... had you previously used FORSCAN to make any adjustments related to this functionality?
For those of you that have the PPOB button on your app, what happens when you press it? Is there another screen or is it just on/off for the whole PPOB system? If the latter, is there an indication showing if the system is on or off?
It just goes to another screen. It only will display the usage.For those of you that have the PPOB button on your app, what happens when you press it? Is there another screen or is it just on/off for the whole PPOB system? If the latter, is there an indication showing if the system is on or off?
The look has changed just today for me.. IT started off one way and now looks different.
They must be messing with it behind the seens. I had it fir a while.. then it went away.. and came back today after the update
Just to clarify, as you mention it only shows status of PPOB and does not have the ability to turn that system on or off?It just goes to another screen. It only will display the usage.
Yes that’s correct. Status only, no controls.Just to clarify, as you mention it only shows status of PPOB and does not have the ability to turn that system on or off?
In other words, the only way to activate PPOB is by unlocking the cab doors or when the vehicle is powered on. Is this correct?
That was how it functioned way back in the old version of Ford Pass, simply a monitoring tool.Yes that’s correct. Status only, no controls.
