Ford App v6.2.0 out for iOS & Android
Question for all members running 6.2.0 and seeing the PPOB controls..... had you previously used FORSCAN to make any adjustments related to this functionality?
shoopg
Garrison
Utah, United States
www.lightningretrofit.com
'22 F150 Lightning Pro | '21 Polestar 2 | '18 Charger Scat Pack | '98 Ford F250
Cloud Engineer
I do have the Forscan changes to enable PPOB with the truck off. 2022 Pro (also in the program that rhymes with shmirly shmaccess)
Albern
Second star to the right
For those of you that have the PPOB button on your app, what happens when you press it? Is there another screen or is it just on/off for the whole PPOB system? If the latter, is there an indication showing if the system is on or off?
shoopg
Garrison
Utah, United States
Cloud Engineer
Ford F-150 Lightning Ford App v6.2.0 out for iOS & Android IMG_6817
Jesse-Infotainment
2024 F150 Lightning Platinum
It just goes to another screen. It only will display the usage.
The look has changed just today for me.. IT started off one way and now looks different.
They must be messing with it behind the seens. I had it fir a while.. then it went away.. and came back today after the update
Gimme_my_MME
Ford F-150 Lightning Ford App v6.2.0 out for iOS & Android bcc0ed6f1a5a4dc955ad0de19604c088
Albern
Just to clarify, as you mention it only shows status of PPOB and does not have the ability to turn that system on or off?
In other words, the only way to activate PPOB is by unlocking the cab doors or when the vehicle is powered on. Is this correct?
shoopg
Garrison
Utah, United States
Cloud Engineer
Yes that’s correct. Status only, no controls.
That was how it functioned way back in the old version of Ford Pass, simply a monitoring tool.
vvgogh
Colorado
'23 F-150 Lightning ER
Ford App 6.2.0
iPhone 17 Pro, iOS 26.1
2023 Lariat, Phone as a Key, 9.6 kW pro power option
No Pro Power in Ford App for me. On the bright side, the charging screen finally displays energy added and time on charger for the current session (this was broken for me in prior version of Ford App).
Kakaratto
Nate
2024 Ford F-150 Lightning Flash
Ford App 6.2.0
iPhone 17 Pro Max, iOS 26.1
No Pro Power Onboard for me either.
I saw somewhere that PPO while the truck is off can be enabled in Forscan? Is there a chance that is required to make the PPO option available in the app?
I can see PPOB in the app. I have a 2022 and tried to enable PPO with truck off in FORScan but it did not work. So I reversed those changes.
Ford App 6.2, iPhone 12, iOS 26.0.1
Ford F-150 Lightning Ford App v6.2.0 out for iOS & Android 1763006246148-97
ScubaSteve_TheReal
Steve
Midwest USA
Derivatives
Same for me, iOS 6.2.0, no PPO
…yet….
No zone lighting…
No trip logs…
Missing these still….maybe someday lol.
Ford F-150 Lightning Ford App v6.2.0 out for iOS & Android IMG_3427
Ford F-150 Lightning Ford App v6.2.0 out for iOS & Android IMG_3428
