FordPass - “Plugged In at Home but not charging”…but, my truck isn’t plugged in!
Firestop
Firestop
New behavior. I’ve successfully been charging with my FCSP and the connection/functionality with my FordPass iApp has worked well. Thursday evening, after driving home, I received a popup alert on my iPhone that my truck is plugged in at home, but not charging.….the problem is my truck is not plugged in….to anything! Clicking on the alert leads me to the attached screen(shot).
Also, I am no longer able to adjust my Departure Times within the Charge Settings screen in FordPass…the app either times out or I get a FordPass communication error. This behavior with the app occurs both when I’m trying it remotely and when I’m inside the cab (ACC & ON modes).
FordPass PAAK still functioning when I’m within range and the remote Zone Lighting feature using the app also works. I am still able to adjust my charge settings within the truck via Sync4A, but none of the changes are not reflected in my iApp.
Tomorrow at 0745 hrs I have a departure time set in the app (turned-off in the truck) with preconditioning….this should be interesting, as I’m not going anywhere tomorrow morning and am not going to plug-in my FCSC?
Any thoughts?
Ford F-150 Lightning FordPass - “Plugged In at Home but not charging”…but, my truck isn’t plugged in! B8794A82-0955-4DC6-BF4E-9D9790FB138F
BennyTheBeaver
2023 Lightning XLT ER
Is there a latch on the truck (charger port) that is stuck? Or broken?
Log out of FordPass, totally close the app out of your phone memory and then log back in. That fixes most problems that aren't caused on Ford's end.
Firestop
Firestop
Firestop
Nope, one of the first things I checked. Operated the charge port door and checked for any debris in the charge port….all clear….latches correctly. It has been cool/cold and dry for ~two weeks, so no opportunities for water infiltration…
BennyTheBeaver
Any codes? Possible latch sensor malfunction?
Firestop
Firestop
Firestop
Thx, tried it …. no joy. I even tried deleting the app and reinstalling (had to reinitialize PAAK?). No change in behavior other than the plugged-in alert cleared on both of these attempts, only to reappear ~1 hour later each time?
Firestop
Firestop
Firestop
MichaelCA
before i got a 3.5.2 I had the same issue. Over night itll give me this message. After 3.5.2/3.5.3/3.5.4 I haven't seen it return. What Power up version are you?
Firestop
Firestop
Firestop
I updated to 3.5.4 on 11/4…….
I've seen this infrequently, especially when I've set a 'departure schedule'... the App may not update to the truck for some time, either the truck is not in a good cellular signal area, or something is causing a snag or holdup. The 'talk' between the app and the truck is not always instantaneous like we might be led to believe, for whatever reason.
but, yes, the app is not always as intuitive and speedy and perfect as we wish.
trev5150
Trev
Pilot of pilotless things
Oh you shoulda been me the other day when I plugged in at work at and it wouldn’t charge, saying that I was outside the specified hours (referring to my home overnight charge window).
I deleted the location for work and replugged, but no change. Charging paused, and I couldn’t add the location again.
Next day, no problem at all. Charge anytime, added the location as if the day before never happened.
It’s like the interstate slowing down to a crawl and there’s n accident to rubberneck, just no reason at all.
Try power cycling the the FCSP, might be a wild goose chase but worth a try.
greenne
Nathan
Niskayuna, NY
I've gotten this error too, out of nowhere many days after charging(and many short drive trips)--truck not plugged in
I believe its a FordPass software issue, not a hardware(sensor) issue.
Once it simply went away on its own after a bit, the other time it went way when I restarted my phone(and Fordpass).
FWIW I also don't have the Ford EVSE installed..I'm using a Chartgepoint flex 48A
I guess that quashes the need to reboot the FCSP.
