How often to charge to 100%?
drdirk
Houston
F150 Lightning Lariat
in 3 years I have maybe once by mistake charged to 100%.
DNap4
22’ F-150 Lightning XLT SR
The answer really is to just go by the manual recommendations. Charge to 90%. Plug it in often. Precondition. Charge to 100% when you need the range.
JMD359
One843657295470895!
22 F150 Lightning Lariat,2022 Toyota Rav4 Prime,2011 F350 6.2L
Mechanic
Ok, thanks. Good to know.
If possibly low xharhe to 100 when the weather is cooler it’s far better for the battery . High temps and high SOC together are what degrade the battery .
Calvin H-C
Calvin
You can charge to 90% everyday. 100% once a month to balance the cells or more of when you need max miles
That's what we do with the Lightning.
Here's some food for thought... My Focus Electric is over eight years old and has over 182,000 km (113,000 miles) on it. When you plug it in, it will charge to 100% unless you unplug it early. There's no ability to set a maximum SOC. At least not through the menus, not sure if it can be changed through ForScan.
So, over that time, I estimate it has been charged to 100% at least 2500 times. I pretty much get the same range I did when it was new. Maybe a percent or two less, but hardly noticable. Last summer, I got some of the longest ranges in the life of the vehicle. That may have been mostly due to more optimal weather, but battery degradation hardly had an effect.
Now, newer battery technologies may fair better by not always charging to 100%, but I suspect that the cell balancing that is done only when charging to 100% is necessary for the battery and should be done at least every one to three months.
My gut tells me that leaving the car sitting for days after charging to 100% is worse than just charging to 100%. When I go away on business, I've always made sure it is not at 100%.
Lytning
Georgia
It’s actually been proven. Little small charges of 10% every day for example are better than draining to 30 then charging 50% in a sitting 👍
ABC (always be charging) to your max you like if it 70/80/90 whatever.
At 11:59 in the video ... "Even if you do everything wrong, it (the battery) will still very likely last a very long time."
mr.Magoo
2022 Lariat ER, AMB
"Proven"...in accelerated / synthetic lab tests, yes.
Few of these tests mimics real life usage (because it would simply take a decade vs. 6 months or whatever it is).
For example, does it cause more harm to have your battery sit at a high SoC (80-90%) all the time compared to a deeper/extended charge cycle once a week ?
Nor do they look at a more realistic range of 30-80 vs. 70-80-90, but we take their 0/10-100% tests as proof that ABC is the "law" we shall all abide by.
Besides, if you're going to ABC it's probably better to be in the 40-60% span than it is to always charge from 70-90%.
Peddyr
Peter
New Hampshire
2022 Ford Lightning Lariat SR
Cyber
With a SR battery and a commute of over 100 miles a day (plus kids activities), I charge to 100% about 4 times per week out of necessity.
Just wondering if it's good for the battery to charge to 100% every once and awhile. I've had the truck since August of last year and it was 100% when I picked it up. I did a max charge for one mid range trip and that's about it.
I normally charge to 80%.
Just do what Ford recommends and charge to 90% most of the time, and to 100% only when needed for a longer trip and you'll be fine, unless there is some kind of battery defect.
Joe Dablock
Joseph
Stewartstown Pa. 17363
I have a 22 MME ER (76k miles) and a 23 Lightning ER (56k miles) and I keep them both charged to 100 percent all the time, and they rarely drop below 50 percent. I also rarely use fast chargers. So far I haven’t seen any battery deterioration in either vehicle. On any given day, I need either vehicle available to go at least 200 miles in a moments notice and only 100 percent charge allows me to make a drive with total confidence.
Theredshift
Kentucky
Lightning
Usps
Everyday.
bc1
McPherson, KS
So, in short, asking on a forum how to charge the vehicle is like asking people what their morning constitutional is. Some empty out in the morning, some are still full of crap, and few actually do what is recommended by experts / manufacturer.
Well now, I didn't know the experts/manufacturer had a recommendation on morning constitutionals. :) Now I need to know what the experts recommend and particularly what the manufacturer recommends for morning constitutionals. I was planning on keeping my truck for the rest of my life but now I'm not sure if it will be me or the truck that dies first. :sadface:
abcut973
Anthony
Denham Springs
2022 F150 Lightning Platinum, 2020 BMW X7 xDrive40i, 2019 Mercedes C300 cab
100% when I have a road trip. So if i have 3 trips in a month i will hit 3 times 100% starting from home using level 2. I never do DCFC to 100 during the trip, max 90% generally for the return.
also target charge for daily use is at 90%. If i have months with no road trip I will charge to full at least once for balancing purposes.
Don't sweat it too much. Just enjoy driving your truck!
Athrun88
Toronto, Ontario, Canada
Like everyone else, 90% for everyday because I don't know if I'm going to drive 10km or 100km that particular day and 100% if I know I'll be driving more than 150km in any one direction. Full charge usually happens 1-5 times per month. I just happened to accidently charge to 100% yesterday and I'm not losing sleep over it. Use the truck now, any concequences will be up to future me to deal with!
