It finally happened! 😳
ctuan13
Chuck
Pittsburgh, PA
Well, guys, I guess it's time to send her to the crusher, my SOH dropped below 100%. 😂
Lol in all seriousness, a bit sad to see, but not unexpected given my truck's age and and now coming on three summers in a row of cross country road-tripping DC charging all the way. All in all, I think I'm doing pretty good.
I'm certain today was the day the BECM decided that I've dropped below 100% SOH, since I checked it just last night and it was reading 100.
06/14/2026
35275mi
SOH: 99.5%
How're you guys doing on SOH and what're your mileage and respective truck ages?
Ford F-150 Lightning It finally happened! 😳 Screenshot_20260614_182024_Car Scanner(1)
Charge to 100%. It may go up to 100%.
Or, take a trip with multiple charging stops.
Calvin H-C
Calvin
I was just thinking that.
Just my speculation, but I believe for the battery's long-term health, it should get a cell balancing at least every month or two. This only happens when charging to 100%.
My speculation comes from my FFE's battery that still gets good performance after 8.5 years and nearly 3000 charges with all the AC charges to 100%.
cjoanzy
Carl
2024 F150 Lightning Lariat
Not sure mileage is hurting your SOH.
My 2024 Lariat is at 41,000 and it is still 100%.
Built in July 2024.
Bought Jan 2025.
Never been on a DC fast charger.
Only use a 40 amp AC home charger. (everyday)
Charge to 95% from mid DEC to mid MARCH. (Philly area cold months)
Charge to 85% the rest of the year.
Charge to 100% once every two months.
What is your available energy at 100% SOC? Since it's warm in most places, lower available energy from cold battery pack shouldn't be a problem. Last couple times I charged to 100% I couldn't get more than 128kWh. I didn't start using my ODB reader right away, so I don't know what it was at new but assuming I had 131kWh as advertised then I'm around 97.7% of original capacity @ 4 years/61k miles. If that rate holds steady I'm looking at 88% left after 20 years/300k miles. I get the feeling I'll have to replace the motors long before the battery.
jefrank
Jeff
Fenton, Michigan
2022 Ford F-150 Lightning Lariat ER, 2004 BMW 330Ci
06/14/2026
35275mi
SOH: 99.5%
Checked mine over the weekend... 100% after 46 months and 48k miles of ownership. The caveat being that I had a module fail late last year so I'm not fully on my original battery.
ctuan13
ctuan13
Chuck
Pittsburgh, PA
I recently charged up to 100%, before I first left PA, but I can try that again.
As for multiple stops, you can bet I've had multiple stops towing from PA to where I am now, Colorado! Still many more to go before I make it to WA!
ctuan13
ctuan13
Chuck
Pittsburgh, PA
Uh oh...
It dropped again...
Maybe I jinxed myself lol
Ford F-150 Lightning It finally happened! 😳 Screenshot_20260615_012531_Car Scanner(1)
Lytning
Georgia
[/QUOTE]
My mileage is WAY higher than my truck's mileage.
The truck's SOH is higher than my SOH.
My age is WAY higher than my truck's age.
Tom M
Bossier City, LA
2022 F-150 Lightning Lariat, 2025 VW ID.Buzz
Pilot, Instructor
22 Lariat Extended Range. Here are my readings at 64000 miles about a month ago:
Ford F-150 Lightning It finally happened! 😳 IMG_8314
CD4TNF
Li battery degradation is non-linear. See the graph in "The Science" section of this article. Meaning a "X% per year battery loss" interpretation is incorrect.
All we can say is EV batteries drop off for a bit at the beginning, then hold steady for a very long time.
https://www.recurrentauto.com/research/how-long-do-ev-batteries-last
There's some lab testing data out there saying the NMC batteries have a 500-2,000 cycle lifespan depending on usage. That works out to around 124,000 - 500,000 miles.
131kWh × 2000 cycles × 1.9 mi/kWh = 497,800 miles.
One other nuance is lab testing is not real world conditions, which is likely why we're seeing such great battery health. I think of it as Engineers over-engineered.
https://www.batteryuniversity.com/article/bu-808-how-to-prolong-lithium-based-batteries
Like you said, drive it until something needs to be repaired and it's not likely the battery.
Randall Stephens
Seattle
2023 F150 Lightning Lariat ER
Jet Builder
06/14/2026
35275mi
SOH: 99.5%
That’s a good looking chicken as your profile pic
ctuan13
ctuan13
Chuck
Pittsburgh, PA
[/QUOTE]
In terms of calendar aging, most would still consider me young, but my health issues mean my SOH is worse than most that are 65+ 😬
JayF
Jay
Tacoma, WA
jay.jvf.cc
2023 F150 Lightning Lariat SR
Open Source Developer
Yeah I'm not convinced that state of health has any significant meaning except in cases of extreme values.
When I pulled the state of health on this truck immediately after purchase, it showed 98%. Today when I just checked it, it showed 99.5%.
