Priority Update: 22-PU0929-BLM-UP
Viet658
Viet
Pomona, CA
2018 Tesla Model 3, 2022 Lightning Lariat ER
Got this update today and says it’s for PaaK but I’ve already had that feature since I picked up the truck in November of last year. This isn’t adding auto lock right? Not home at the moment to test it.
Ford F-150 Lightning Priority Update: 22-PU0929-BLM-UP IMG_9420
Seems there are 3 updates out this last week or so. At least one notes it could just be an update of previous release. I'm not sure what they are doing other than just trying to blanket the trucks and get software out to some that they missed or didn't take the first go round. The release numbers for these are at the bottom of the text and don't follow most of the previous names..
My truck has had PAAK from day 1 and I was not sent a letter. But this update has been trying to install the last several nights at the scheduled 1 am but failed. Tired of the daily notices, so I put it on my FCSP and kicked it off manually once above 80% SOC and it installed fine. As mentioned in another recent update there is very distinct loud "wasp nest" sound near the spare tire for several minutes. Fortunately no change to PAAK, seems to work as before.
luebri
Neenah, WI
Same thing my blend date brother. PAAK from day 1 but got this update last night
EdRudy
Ed
Springfield, VA
Same here, PAAK since day 1 but got the update last night. Hope it still works this evening, I haven't carried my keys in months.
Reactions: kab
ddbrooke
Natrona Heights, PA
F150 Lightning
This showed up yesterday in my Ford Pass app. I guess it tried overnight the last two nights and failed. I tried to force it today and it failed. It's scheduled for 1am. It will probably fail again. I've had PAAK all along so I guess this is additional code that solves some other problem.
I have a service appointment for the rear light bar replacement and the wheel ting washers next week. They've already told me that they see two modules that need updating and one of them sometimes takes 12 hours to complete. I'll let them deal with this if it doesn't go on it's own.
Still works for me but it reset my radio stations and re-enabled brake coach.
ddbrooke
Natrona Heights, PA
F150 Lightning
After 5 scheduled update fails and 2 'update now' fails, I found the 12v battery modules in Car Scanner and added them to a page on my dashboard. What I found was my 12v batter voltage was at 14.45v but my 12v batter SOC was only at 46%.
So I plugged the truck into my FCSP and let it charge overnight while the software update was scheduled to kick off at 1 am.
To my surprise the update completed! I plugged my OBD into the port and found my 12v battery was still at 14.45v but the SOC was up to 85%.
So does that mean that update failures are not only related to low voltage but also to SOC? Looks that way.
Ford F-150 Lightning Priority Update: 22-PU0929-BLM-UP Before charge.PNG
Ford F-150 Lightning Priority Update: 22-PU0929-BLM-UP After charge.PNG
Reactions: GDN
eRockBoon
Erik
Kansas
Wish they would give PRO trim trucks PaaK!
