Konakid
- Dec 3, 2023
- Kona, Hawaii
- F150 Lightning, Kia Niro PHEV
I have a 2023 F-150 Lightning XLT with extended range battery. Within the truck I can set a permanent charge limit for my home charging station, or I can set a one-time charge limit. The problem is, neither of these work! The software accepts my change, but actually charges to whatever battery percentage it was previously set to. Right now I have the home charging station limit set to 85%, and it will show that whenever I look at it. But when I actually plug the charger in, it shows that it will charge to 100%, and it will actually continue charging toward 100% until I physically unplug it. I should mention that I was actually twice successful in changing that permanent limit, but most of the time it doesn't work. And the one-time limit has never worked. Also, in the FordPass app on my phone, I have buttons for "stop charging" and "charge to 100%". These also almost never work. I called Ford about this problem, and was told that "it's a known issue and will be addressed in a future update". But I haven't seen any complaints about it on this forum. Have others experienced this problem? I consider it to be a major issue not being able to set the charge limit. For awhile my limit was stuck at 85%, and I was unable to get the truck to charge to 100%, meaning there were certain places I could no longer drive to!
