imnuts
Dirty Jerz
'21 502A Powerboost 4Ă—4
Facilities Engineer
Well, I've completed 13 updates successfully so far, currently working on #14 (APIM) that showed up after the IPC update, which was the last one I did on the initial list in FDRS.
Fordphanatic
Boothwyn
2021 Platinum F150
Union Carpenter
Did you have any issues with the IPC update? With downloading or install
tonesto7
Anthony
2021 Lariat 502A | 3.5L EB
IT Admin | Software Developer
How about when it shows modules as 'unknown'?
You can ignore that... The next release will have a lot more nodes mapped and descriptions.
My goal is to provide us with as many details as possible about our vehicles :)
Jaug
Jason
Fargo
2021 F150 Platinum
Ford F-150 Lightning ECU module programming guide using FDRS 8B70033F-7863-4D3C-BAED-7AE4CB4C3AEF
I am assuming this is corruption in the I know nodes. This is from my APIM
imnuts
Dirty Jerz
Facilities Engineer
Well, everything went well. Completed all the updates in FDRS over the course of ~3½ hours. Here's the order I went in and how the middle updated for people's reference.
GWM - USB
PCM - multiple modules - CAN
ABS - done w/PCM - CAN
SOBDMC - done w/PCM - CAN
BECM - done w/PCM - CAN
TRM - CAN
DSP - CAN
DCACA - CAN
DDM - CAN
PDM - CAN
SCCM - CAN
GSM - CAN
IPC - Engine on - USB (1st) & CAN (2nd)
APIM - Engine on - USB
The only update that wasn't in my list that I was expecting was for the IPMA. I'm going to check again later to see if it shows up.
The first time I tried the IPC update, there was an error on the download step. I tried it again and it went through without an issue.
antho
Anthony
Houston, Texas
2021 801A Raptor
So i've had Fordpass integration (itchannel) on my Home Assistant for about a year and a half. I Made a pretty cool Card awhile back for my HA dashboard and made sensors etc. Low and behold i started looking more into the Github and of course @tonesto7 has even been killing it over there too!
Bob_Mac
Bob
North Carolina
2021 Ford F-150 Platinum
Cyber Security | Developer
GWM - USB
TRM - CAN
DSP - CAN
DCACA - CAN
DDM - CAN
PDM - CAN
SCCM - CAN
GSM - CAN
Your GSM updated? Most like myself, it goes through the process and completes but never disappears from the SW Updates tab...
imnuts
Dirty Jerz
Facilities Engineer
Yeah, it updated, but that and the ABS module are still in the list. Is there a list of the latest software versions for the various modules? Just want to know that my IPMA is up to date.
Also, didn't post it previously, but no issues at all with Windows 11. I did pick up a USB hub after I was done. My Surface tablet only has one USB port, so I was switching back and forth between the USB drive and the adapter a couple times. It didn't seem to cause any problems though. I got the WiFi version of the VCX Nano, though I stayed connected via the USB cable when needed.
I do want to know how critical the voltage is though. When I was updating, the voltage stayed at 12-12.2V. When the ignition was turned on, it would jump up, but for the most part stayed at that level the entire time. I had the charger hooked up, and it was definitely working because it got warm. Using a NOCO Genius 5. The guide says not to do anything if it's under 12.5V, but I didn't have any issues.
jcaspar
Sacramento CA
2021 F-150 4x4
Has anyone had this error with the BCM update? Have tried it several times and still getting the same error.
imnuts
Dirty Jerz
Facilities Engineer
I had a similar error that came up when I went to run the ABS update after it was already applied.
JEB
Northern Illinois
2021 F-150 Lariat Powerboost
The GSM and ABS may have appeared to run to completion without throwing a visible installation error, but unless you saw it actually writing data blocks, it probably didn’t actually update. I was curious about this as well as well. Looking at the installation log for the ABS, although there were no installation failures, per se, the nodes all reported that the software was called but failed to install because it “could be optional.” This is a representative piece of a fairly lengthy installation log from my last attempt to install the ABS:
Software part: SBL: ML34-2D052-AA from GIVIS
Software part: F188: NL34-2D053-CA from GIVIS
Failed to get F120: null from GIVIS - Could be optional
So, if the GSM and ABS are still being offered, they probably didn’t install. But it isn’t a problem because FDRS probably checked the software when you ran the routine and determined that an update wasn’t necessary. Why the updates continue to be offered I don’t know.
imnuts
Dirty Jerz
Facilities Engineer
It was working data blocks when the updates ran, and didn't say there were any errors. I tried to re-run the ABS update and then got an error, though I didn't screenshot what it was.
jcaspar
Sacramento CA
2021 F-150 4x4
Got it to work! Had to have the door closed when I updated!
jcaspar
Sacramento CA
2021 F-150 4x4
How long does it take for new software updates to show up? I have done everything and only show the ABS and GSM remaining. I have NEVER done a network scan so I am wondering how quickly the cloud will learn that I have completed the updates. Also, had to restart FDRS before competing my APIM update (which worked) so never got to tell it that I completed it. Thank to all for helping me get this all done!
Jesse-Infotainment
2024 F150 Lightning Platinum
The IPC update seems to be ok now. They seemed to have sent out the correct update.
Edit.. The IPC is TWO parts - I know I mentioned that previously. First is a USB update and the last is CANBUS So please pay close attention as you do it.
