20ecoboost21
South Carolina
2021 F150 tremor
Those that had the CCM fail using the Nano, when it tried updating did the ignition turn off by itself when it starts doing the Block 1 of 2 erase process cause that's what mine is doing.
JEB
Northern Illinois
2021 F-150 Lariat Powerboost
@Jesse-Infotainment @iceman77 we have an issue. My updates were fine when installing and now I am having issues as others have indicated. Taking a drive bought it to my attention when I saw "Pre-Collision Assist Not Available". I'm getting the extra 'ML3T after whitespace and a persistent DTC U2101 and using the Mongoose, see below:
I looked up IPMA DTC U2101 in the shop manual. It provided the following description: “This continuous memory DTC sets when the IPMA As-Built data installation was not installed completely or incorrectly.“ Shop manual further says the fix is to: (1) clear the DTCs; and (2) Install IPMA As-Built data from PTS following scan tool instructions. Can you reload the as-built data via FORScan or the FDRS module configuration tool?
Jesse-Infotainment
2024 F150 Lightning Platinum
Any update the truck is going to shut off the screen will be on
Jesse-Infotainment
Bob_Mac
Bob
North Carolina
2021 Ford F-150 Platinum
Cyber Security | Developer
I looked up IPMA DTC U2101 in the shop manual. It provided the following description: “This continuous memory DTC sets when the IPMA As-Built data installation was not installed completely or incorrectly.“ Can you reload the as-built data via FORScan or the FDRS module configuration tool?
I did in both FORScan (forced) and FDRS Configuration
Jesse-Infotainment
Jesse-Infotainment
Well I thought I did but that is the correct change.
IF that is what the actual module is showing. Is that what it shows in Forscan?
The old config was
8A58 - A215 - 8Cxx
Not sure if you did the headlight change.. but if the new config is not working it may be an issue with the file loaded. Need to confirm the files were replaced..
The new as build is what you have except the
Xxxx - xxx8 - xxxx
That I don’t believe is standard. I is lol have to look but if I were you I’d write a as build straight from a 22 to see if the error goes away. Just that top line.
You could also write it back to what it was prior to and see if it goes away.. if it does we know you had an issue with a file
Bob_Mac
Bob
North Carolina
The old config was
8A58 - A215 - 8Cxx
Xxxx - xxx8 - xxxx
I did the FORScan change to Disable Auto-Reverse Braking & Alert... let me reset back to defaults
Fordphanatic
Boothwyn
2021 Platinum F150
Union Carpenter
So your reverse brake assist is back to normal
Bob_Mac
Bob
North Carolina
The old config was
8A58 - A215 - 8Cxx
Xxxx - xxx8 - xxxx
Ok, we now have a serious problem and although I don't think this affects everything but, FORScan changes could make life rough when doing updates. I changed it back to the default and the error as well as the DTC are now gone!
Jesse-Infotainment
Wel at least it’s gone
