Finished installing my charger & generator manual transfer switch [to provide emergency power to my house using 240v 30a plug in the truck bed]
jefro
F150, Corvette, Bolt EV,
Wonder when code will make us put in a disconnect within reach of EVSE like AC and HWH.
It’s already a requirement to have a disconnect for an EVSE either within sight, or lockable.
Brotato
Brotato
Portland, Oregon
F-150 Lightning
California for example already requires this. Some other states I found said its just for 60a or more. It wouldn't be a bad idea to put one in.
The 60A is spelled out because they must be hard-wired. For cord and plug connected equipment, the plug counts as the disconnect.
But the 2020 NEC requires a disconnect for all. The plug still counts, but hard-wired would require a disconnect regardless of amperage. Quite a bit of the US has not yet adopted the 2020 code yet.
Brotato
Brotato
Portland, Oregon
F-150 Lightning
Thanks for the insight, this makes sense.
Solar_EE
Roger
F150 Lightning XLT Ioniq 6 AWD
electrical engineer
I wanted to share my project I just finished that will let me use the 240v 30a plug in the truck bed to provide emergency power to my house. At the same time I ran a new line for a 48amp charger for the truck.
I also have a solar grid tie inverter (blue box) and Emporia Vue energy monitor (mess of white cables in the box). Not part of the backup system.
Happy to answer any questions!
Parts
  • Reliance Controls 10-Circuit 30 Amp Manual Transfer Switch Kit
  • Emporia 48a WiFi EVSE
It looks like your L14-30P is energized when you are charging your truck. This is dangerous- the box says to "connect your power cord before starting the generator". Do you connect to your Lightning with an L14-30 extension cord? I suppose you do this only when the manual transfer switch is disconnected from the grid.
Solar_EE
Roger
electrical engineer
Now I see that you have separate wires- so this power inlet goes to your manual transfer switch?
Solar_EE
Roger
electrical engineer
I didnt connect any large loads such as AC, electric water heater, etc. This will only support the lowest load circuits such as fridge, lights, office, etc. From what I have seen, the Ford app will show you the load on each leg of the 240 circuit which hopefully will make it easy to manage.
When will your truck arrive to test this?
FlasherZ
St. Louis Metro
My county is still on 2008. :)
watchdoc
2022 Leaf SV+, 2016 Ram Big Horn
watchmaker
Do you have an additional battery backup? What solar inverter are you using? If the grid goes down, does your solar inverter still supply power?
RickE
Rick
22 F150 Lightning Lariat ER
That’s what I suspected. Technically, that‘s a code violation. But it works fine - electrons are color blind. ?
Simply get some green electrical tape and tape up both ends of the white wire with it. Code violation gone!
