- First Name
- Greg
- Feb 15, 2022
- Dallas, TX
- Lightning Lariat ER, Performance Y
- Occupation
- IT
We don't have a lot of data yet, but @OutofSpecKyle actually had 170kWh or maybe (171) I forget which, in his charge session, he showed this in his video. He started at a much lower SOC than Tom did in his video. So it is hopeful to hit this peak at least.Important to note how each Charge Station charges (Per Minute or Per KW) and the maximum charge speed (up to 150 kw/h). Reviewers to date have found maximum speeds for the Lightning at 120 kw/h 0%-80%, then dropping off to half or less. Also, choose locations with more than a single station in case of disrepair.
Either is truly abysmal for Ford and a battery this size. they should be able to hit that lower 40% with 250 at a minimum then slow the rest of that curve down to maybe 150kWh.
So many good things about this truck, but the few key things about a BEV are the well, the battery, the charging and the motors and so far Ford isn't showing they excel here.
