Phone as a Key issue
Whammy Bar
Anyone that has got their PAAK working... what am I doing wrong?
Greyed out in the truck, and nothing about setting up a key in Ford Pass.
Software version 3.5.2
GrokTime
Sean
Ithaca, NY
Toyotas + incoming F150 Lightning
I think the only way to activate PAAK is if you see the option to set it up on the main screen of your Ford Pass app.
petemill
Pete
Santa Barbara, California
'22 ER Lariat +PRB +Unleashed, '11 ford escape v6
Software
I was 7/25 build week - Lariat ER.
PAAK worked the day I picked up the truck August 30. It's worked flawlessly ever since with iOS and iPhone 12 Pro.
The backup passcode to start the vehicle has worked without any issues at all for the few times that I've gotten in without my phone.
The truck came with 2 key fobs. I haven't used either of them once!
Very impressed.
Your truck was made before July 25. We don't know the differences or hold up, but all those before are in the same boat. At this time - nothing we can do.
Whammy Bar
Blend date was 8/3. Took delivery 8/30.
white lightnin
Missouri
raptor
My PAAK started working yesterday! It is awesome. I know for a fact that it was not due to any OTA update. The issue I had apparently was on Ford's server side and it affected a few hundred trucks. The problem was corrected on the Ford server and the PAAK showed up almost immediately on Iphone app. Everyone that had PAAK show up yesterday had this specific issue corrected. I am uncertain to the exact issue that caused the problem.
ETA: I would like to thank Ford and everyone there that is actively working to make the truck better.
tx_lightning
TX
2013 F150, 2022 Lightning XLT XR
Galactus55
Gus
Ontario - Canada
My PAAK works OK
Truck built 07/29/22
Ford F-150 Lightning Phone as a Key issue 1662902428733
metroshot
Pat
Montclair, CA
2022 Lariat F150L + 2023 MME
Networking Tech
LightningMcqueen
Justin
Austin,tx
2017 F150, 2021 Bronco Sport
Where in the Ford Pass app, do we enable PaaK?
You'll see it right up front when it is available. It is not available yet on your truck, only trucks built after 7/25. Prior trucks need SW updates which have not been pushed.
Just today it is verified you can do FDRS updates manually yourself and add PAAK, if you are into that thread and the time and money to do your own updates. https://www.f150lightningforum.com/...e-updates-using-fdrs.11029/page-3#post-259233
LightningMcqueen
Justin
Austin,tx
I might be inclined to go to dealer and get it updated?
