ktom
- First Name
- Kevin
- Aug 15, 2024
- Austin, TX
- 2023 F150 lightening, 2022 Tesla Model Y, 2014 Audi S5 6/spd
- Occupation
- Self employed
I went to get some blood work done early in the morning. Used the PAK to get there. Standing outside, waiting for the office to open, within eyesight of the truck. I noticed that the lights blinked and the horn honked on the truck. I asked myself, why would that happen?
I finished the blood work. On the way out to the truck I realized I didn't have my phone. I had left my phone in the truck.
I tried the door entry code I had set a long time ago. It didn't work!! None of any of the possible codes I might use worked!!
So.. the conclusion of all this is...
Some update along the line, erased the door access code. Unless you need the door code you don't know that it has been erased. Check it periodically. I didn't get a printed manual so there is a no place to look for the required "factory code" that is needed to set the door access code. The dealer here, wanted to charge me an hours labor for this code. I had to convince them that an update erased it, therefore I should not have to pay for the code.
The phone is an android, and it seems that when the phone goes/went to sleep, it disconnects from the truck. Hence the reason the truck locked itself. The ford app, it seems, is unable to be active in the background.
Had anyone else had this happen while leaving the phone in the truck?
What is the proper behavior when a phone is left behind?
Should it stay open until the phones dies?
Should it have time limit?
Should it behave as it did, when the phone sleeps, the truck locks?
Should it behave as it did, if and only if there is a non "factory" door code?
