- First Name
- Greg
- Feb 15, 2022
- Dallas, TX
- Lightning Lariat ER, Performance Y
- Occupation
- IT
Im on 3.5.4 and I’m still able to set charge limits via the iOS app. It’s under the vehicle tab -> charging drop down -> charge setting -> preferred charge times-> saved locations: (before you save it, it’ll be under previous locations)
I wish we could set a global/default for all charges because the above method would be a huge pain if you move around a lot. Side note, it took me like 3-4 tries for this to save properly. When I’m hooked in at home, I can bypass my preference and have it charge to 100% via the app or stop the charging early.
Thanks for that info, both of those options are greyed out for me now. I had access to them at one time. Do you have access in the truck now? If so, is that new?
My version of the app is 4.22.0. Are you running the same version?
Also under the "Features and Settings" drop down I gained access to items I didn't previously have.
