Adaptive Cruise Control, if R/L turn signal on, temporary acceleration?
GoodSam
Good
occupying space
p278 "Note: When you are following a vehicle and you switch on a turn signal lamp, adaptive cruise control may provide a small, temporary acceleration to help you pass."
Has anyone experienced this? Does this mean when you are following someone and indicate that you will be changing lanes with the turn signal, then immediately an acceleration is added, even before moving out of the lane? Seems weird.
I would think that this acceleration would occur only if you are going under your set speed, and you have moved out of the lane from behind someone so that there is more than your set adaptive gap availble.
Joneii
Central PA
F-150 Lightning, Tesla MY
The vehicle does accelerate after you move to the clear lane, but I honestly haven’t noticed it as an “additional “ acceleration. It feels quite smooth and natural. The adaptive cruise and Blue Cruise functionality while changing lanes has been surprisingly good. I like it better than my Model Y. It just feels normal and there is no fighting for who is controlling the vehicle.
xycarp
SE Michigan
2021 Bronco Sasquatch, Lighting Lariat ER on order
I assumed it accelerated as I was changing lanes because I was moving out from behind a slower car.
I'm confused. Manual is quite clear. Makes total sense.
hopefully it would not accelerate BEFORE you leave the lane, since you may only be indicating that you are about to TURN.
Wsl346
Austin, Texas
I am ecstatic to hear that the lightning has this feature. My wife's Volvo has this feature and it makes driving in moderate traffic on the highway a little less stressful. My Audi will not accelerate from behind someone going slower than you until you are completely in the other lane which can be frustrating if you are trying to get a move on. I often have to give it a little acceleration manually.
greenne
Nathan
Niskayuna, NY
My Buick wagon(aka Opel) has this feature as well. It smooths out the adaptive cruise as you "signal" your intention to pass--makes it less jerky. Feels very natural to me, like how you would do it if you were to pass and not use the adaptive cruise.
It actually does accelerate before you leave the lane. In fact, it does EXACTLY what the manual says it does - " When you are following a vehicle and you switch on a turn signal lamp, adaptive cruise control may provide a small, temporary acceleration to help you pass".
This is exactly how it has worked for me, set point of 70, eventually I creep up to a slower vehicle, I slow to their speed, then I change lanes (with or with out using signals [mass-hole driver here]) the truck accelerates to my CC set point, after getting around the slow-poke I merge back to the center lane maintaining my set point until the next slow poke rinse wash repeat.
