Twistier in frunk
kbuicker
Kevin
Dallas Texas
2022 Lightning
Has anybody found any replacements that actually stay together for these twist
Ford F-150 Lightning Twistier in frunk 7B76D2DE-CF5F-46B4-9C63-57684481A5DB
knobs on the inside of the frunk? Maybe some that are metal?
kbuicker
kbuicker
Kevin
Dallas Texas
2022 Lightning
I'm just going to buy a bunch of wingnuts and call it done. Tired of these little plastic dohickies breaking or seperating when I want to check m y coolant level.
georgepearkes
George
Charlotte, NC
F-150 Lightning Lariat ER
did you end up replacing them? The backing on one of mine popped loose today, wondering what I should do for replacement. couldn't even figure out what to call the fastener for a bit! there are two kinds, with the single-part plastic ones performing fine as far as I can tell. It's the two-part ones where a "washer" piece can break off that creates issues.
kbuicker
kbuicker
Kevin
Dallas Texas
2022 Lightning
I've not yet actually. I figure one bolt/screw, a rubber washer, a metal washer and a wingnut should do. The holes are .25" wide, and the plastic twists they use are .5" in length. I was going to use a RUBBER washer on the bottom to see if it keeps the screw/bolt in place.
Blochead21
PA
Black 22 XLT 311pkg
Looks like the oem part is W710282-S300
Ford F-150 Lightning Twistier in frunk AC990EF3-F8E4-4660-B2CD-3BC241760274
Ford F-150 Lightning Twistier in frunk B510AD0F-7BDE-4D2F-8A70-75B1D1CF914F
kbuicker
kbuicker
Kevin
Dallas Texas
2022 Lightning
Dang! $11 for one? We have a treasure trove under the hood! :)
