“Charging Ended Truck may have been unplugged”
Pod
2023 AMB Lightning XLT SR
Getting this message every time I end charging at home with Ford Mobile Cord. I’m ending on the app and releasing the cable. What step am I missing? Why am I getting this message?
Pod
Pod
Hmmmm…maybe. I just lowered the charge level to 80%. We will see if that changes it.
khatch
Kevin
Plano
2004 F150, 2021 Bronco, 2023 Lightning
I always get that and have wondered if there is a "right" way to end a charging session.
For Level 1 or 2, charging stops when you depress the thumb latch on the J1772 connector. Then unplug it.
khatch
Kevin
Plano
That's it? No pushing the charge unlock button next to it? No stopping charging through the app?
Would that it t'were so simple.
cwstnsko
Mesa, AZ
2023 F150 Lightning Lariat ER
I got that message once at a Fast Charge station. It might have been the time when I pushed the unlock button to stop the charge. Lately, I’ve been pressing the stop charge button on the station, and I haven’t gotten the message.
When charging at home, I just press the latch on the connector and pull it out of the truck. I never get any messages at home.
I’ve been doing it that way on my Mach-E for almost 2 years, Lightning for 2 weeks.
The charge unlock button is only for DCFC.
Yesterday I got that, figured it was a glitch having just received 4.1.2 a couple minutes prior to starting my charge session.
I set a goal stopping point of 83% initially, but later when it was nearly done I noticed the rate a 80% was only 50KW, which is low enough that the 24c/min rate is more costly than home charging.
I adjusted the console limiter to 81% to allow the truck to command an automatic stop of the charge session, which it did about 20 seconds after saving the new limit.
About 30 more seconds and the EA dispenser switched to Idle timer mode, waiting the last electron to drop out of the cable (LOL)
I got out, depressed the latch button on the EA handle, the truck unlocked the latch, returned to dispenser
The dispenser summarized the session costs, I clicked finish.
Got in the truck, started her up and drove away, seconds later I got a text and email alert for my session fees as I usually do.
About 2 minutes later while driving, another FP alert suggesting I accidently unplugged.
