bewbie
NYC
The vertical bars when connected via bluetooth is your phone signal.
You can maybe find something here in the bezel diagnostic menu:
I took a look and this is what mine shows me, I also maybe found out how to check the trucks cell service if someone can verify for me, it will be shown in the last picture (low service=no update?)
Ford F-150 Lightning Ford Power-Up 4.1.2 UI Update CA79E4DD-B97C-4EEA-AB41-AFF1C2A60245
Ford F-150 Lightning Ford Power-Up 4.1.2 UI Update 8E0F03F3-7C07-46F5-BAAD-EA7C9463316E
Ford F-150 Lightning Ford Power-Up 4.1.2 UI Update 482E375F-BAD3-4B9F-8C8D-4672408376CB
Ford F-150 Lightning Ford Power-Up 4.1.2 UI Update 6FD2E1A7-9266-4A61-A287-83C8BD68BED9
ExCivilian
'22 Platinum
I haven't played around in those menus but I've long suspected a lot of the sluggishness being reported is due to information being collected on the backend. So those settings with analytics and logging tend to underscore that belief.
wighty
NY
I haven’t received any updates since maybe September of last year! Is that normal?
It maybe worth mentioning that I own an XLT
Today was the first update I can recall getting on my base trim XLT
ChrisCon
The Hamptons, NY
this is the signal connection you currently have to AT&T .. it’s only 2 bars . You need sustained 4 bars for updates
Ford F-150 Lightning Ford Power-Up 4.1.2 UI Update C1131A2D-1F4A-45F8-8C1F-1189C148597E
ChrisCon
The Hamptons, NY
3.6.2 has only been mentioned 11 times over the 3 days and never before, the numbering and release control scheme is fouled up IMHO
I never had this on my updates, I see the post at this thread concerning 4.1.1
https://www.f150lightningforum.com/...ta-software-update-released.13570/post-295660
The Mach - E for the 3.6.2 update . The lightning did not . @Ford Motor Company made a mistake on their post and apparently haven’t visited us over here in the past few days to correct it . It’s possible 4.1.1 or the DTE update pushed this feature but I’ve been testing it and I’ve noticed no difference at the DC chargers I use. .. I bought an OBD2 reader that comes tomorrow to verify battery temp with and without using navigation to know definitively .
There is one way to install 3.6.2 . You go to the main Home Screen and on the image of the lightning in sport mode press up, up , down , down left, right , left , right ,b,a and that will enable 3.6.2 mode .
Jer
Jer
Oklahoma
‘23 Lightning Lariat,‘21 Bronco, ‘17 F350, ‘76 K20
Ford F-150 Lightning Ford Power-Up 4.1.2 UI Update 1674701027964
That doesn't enable 3.6.2. It gives you a perpetual full traction battery and changes all the Ford badging to Konami.
CRAIGC540
Craig
Moreno valley
Technician
I just received 4.1.2 one day after activateing the free 3 month streaming trail. ? That and my wife drove 22 miles to the dentist, it updated while she was there.
SmoothJ
New Jersey
2022 F150 Lightning
I was updated to 4.1.2 this evening. Yesterday I noticed a “large” download (84MB) and then a few drive cycles later, it was updated. My vehicle is connect to Wi-Fi and I have a connectivity plan through ATT. However I have pretty bad connectivity (only 2 bars) when at home.
Ford F-150 Lightning Ford Power-Up 4.1.2 UI Update EA2901D7-8A8F-48F1-B8BC-AD1BA4224BAD
Ford F-150 Lightning Ford Power-Up 4.1.2 UI Update 4F1C3047-F52E-4A15-BFD2-D44BE71B9461
