Battery showing 94%
TBA
CA
23 Lariat ER+Tow Tech & Max Tow; Anti Matter Blue
Battery level shows 94% what does this mean? Does it mean that my battery has degraded to 94%.
Ford F-150 Lightning Battery showing 94% E8B1A121-3533-451C-A612-38CB662EB50D
BennyTheBeaver
That is available motor power, not battery percentage.
Think of it this way, if flooring your accelerator is 100%, currently you can only get 94% of your power if you floor it. The truck typically does this when there are temperature issues. If you have a more severe degradation (below 60%) and it never goes back up, then you may have a battery/motor issue.
As said above this is common in cool conditions, your trucks current SOC is showing under 50%
Replika
United States
MR. PLOW - ER Lariat
I'm surprised how little the power drops at low charge. Even around 5-10% this thing still boogies.
sotek2345
Engineering Manager
Agreed - way less power drop off at low state of charge and cold temps vs. our Mach-e GT. I am very impressed!
This stuff is scary.
What's scary?
Do you expect to start your ICE F-150 in 20 degree weather, pull out, and stomp on it and get 100% power output? Doesn't happen.
What's scary?
I THINK, you missed Tonys sarcasm.........
