eRockBoon
Erik
Kansas
F150 Lightning Pro (extended range)
? I’m sure they’ll be posting pics soon, I too want to see it lowered although I opted for the lift. So far the feedback from them is that the lift rides and handles amazing. They should be putting on the lowering springs today.
Can not wait for more details! Any idea is the lift is just front coil overs? Or rear as well? It would be nice to have something somewhere between OEM and the $30,000 suspension swap from Saleen.
F150ROD
F150ROD
U.S. Navy Retired
It’s going to be front coil overs and rear shock spring
eRockBoon
Erik
Kansas
Great! I am even more excited and can not wait to see your truck and their details on the lift. However, I am a bit concerned I went a little too big with my current tires.
F150ROD
F150ROD
U.S. Navy Retired
Either an inch lower in the front or an inch higher in the rear and that would be perfect for me.
I want to say that is what they are looking for, to leave a bit of rake, no noticeable but there.
ninjaybot
CA
22 Lightning Lariat
I’ll be buying the coilovers the minute they go on sale. Can’t wait. Any idea when the hit the market?
F150ROD
F150ROD
U.S. Navy Retired
Better pics, they were able to get 2.6” lift up front, stock rear height with rear using Eibach shocks
Ford F-150 Lightning Eibach R&D for Lightning lowering kit, leveling kit and lift kit -- submit your input CBAD383C-744E-4E04-A63F-B222B65DE0E1
Ford F-150 Lightning Eibach R&D for Lightning lowering kit, leveling kit and lift kit -- submit your input B27F3259-CBC3-4409-B279-D3B6252AA177
Lowered, didn’t get Specs
Ford F-150 Lightning Eibach R&D for Lightning lowering kit, leveling kit and lift kit -- submit your input 8D8433DA-30C4-4722-9A7C-7C3F6234A5EE
Ford F-150 Lightning Eibach R&D for Lightning lowering kit, leveling kit and lift kit -- submit your input 3684DC11-CC0E-44C9-AE1F-2186846ABEF0
eRockBoon
Erik
Kansas
Better pics, they were able to get 2.6” lift up front, stock rear height with lift in rear using their shocks
That is their stage 2 suspension system?
sotek2345
Engineering Manager
Very interested in that lowered setup. Can't wait to learn more!
Strangatang
Dan
NJ
2022 Ford Lightning
Is the lowered only on the rear?
F150ROD
F150ROD
U.S. Navy Retired
The front and rear both have lowering springs/shocks. I believe they only lowered the front about 0.5", their goal was to sort of level the rear with the front instead of slamming the truck all the way down. The Lowering springs themselves were made to fit stock struts but will also work with Eibach struts if you want the full kit.
I suppose if they get enough inquiries they will make a true full coilover kit to give the option to slam it all the way down.
As far as the lift kit, I have been riding around with it for the last couple of days. This is their Stage 1 which means the fronts are not adjustable. For what I was told, they are not going to be looking to make a Stage 2 kit (Adjustable fronts) but that could change. So far it feels and drives firm, not harsh but not soft. It is very comfortable but it's not luxury comfort like it was stock. I am perfectly fine with this as now it feels and drives sportier despite being raised. You do feel the road a bit more which I prefer and it soaks up bumps/imperfections with no problem. My wife stated as a passenger she notices no difference in comfort which tells you there is not a drastic change as you usually have when you toss out stock suspension.
I did not get a chance to ride with the lowering springs, so I cannot comment on the comfort of those.
Stock Pic for comparison:
Ford F-150 Lightning Eibach R&D for Lightning lowering kit, leveling kit and lift kit -- submit your input IMG_5243
So here is my summary on the two suspension setups I've had from Eibach:
Front leveling height adjustable shocks (Prototypes, I believe these where from the ICE F-150):
- Gets rid out the bounciness when hitting dips
- No difference in ride comfort
- Levels the front with rear with a slight rake
- Handling improved slightly with less body roll
- Cost is roughly less than $350?
Ford F-150 Lightning Eibach R&D for Lightning lowering kit, leveling kit and lift kit -- submit your input D72FD6DE-972F-4126-837E-A7863B3C1450
Stage 1:
- Firm, controlled, all bounciness is eliminated.
- Handling improved significantly, you can't really feel any body roll unless you truly push it around tight corners
- No rake noticeable
- Ride comfort is mostly the same as stock but firmer
- I forgot to ask if the fronts are adjustable but I will ask Eibach
- Not sure about cost
Ford F-150 Lightning Eibach R&D for Lightning lowering kit, leveling kit and lift kit -- submit your input IMG_1619
Ford F-150 Lightning Eibach R&D for Lightning lowering kit, leveling kit and lift kit -- submit your input IMG_1647
Ford F-150 Lightning Eibach R&D for Lightning lowering kit, leveling kit and lift kit -- submit your input IMG_1646
Lowered Pic, I have no feedback on these:
Ford F-150 Lightning Eibach R&D for Lightning lowering kit, leveling kit and lift kit -- submit your input IMG_1622
If anyone has any question they want me to relay back to Eibach R&D please let me know.
T i h o r
Rohit
Toronto
Self Employed
+1 to go even lower. I have a problem and need to lower all my cars. I even slammed my wife's van ?
eRockBoon
Erik
Kansas
Bummer! I was dreaming of something like the Pro-Truck stage 2 system like that they have for broncos. Capable of at least 3 inched in the front.
