abel408
- First Name
- Chris
- Dec 15, 2022
- Schenectady, NY
- 2023 F-150 Lightning Pro
Hi all,
I've been experiencing an odd issue with my TPMS sensors and keyfob. While I'm driving, I'll get a notification that their is a tire pressure fault and 1 or more of my TPMS sensors will disappear from my dash. In addition, if I have the keyfob in my pocket, I may get a notification while I'm driving that the keyfob has left the vehicle. If I take the key out of my pocket and place in closer to the dash, it seems to find it again. I've also noticed that at times I have to be literally right next to the truck to lock and unluck with the keyfob.
The problem is intermittent and I haven't yet figured out what triggers it, but it seems to happen more often when the weather is warmer (higher than 80 degrees). My tire pressure also increases to above 40 when it's warmer, so I'm not sure if that's related.
I've installed the LED emblem and a powetrax tonneau cover (the one with the remote) a month ago. The problem didn't immediately start after I installed them, but I'm not sure if they may be causing an issue.
I found this recall for the 2021 F-150 and it seems to describe my problem exactly: https://static.nhtsa.gov/odi/tsbs/2021/MC-10201583-0002.pdf
Scheduling an appointment with the dealership, but I wouldn't be surprised if the problem doesn't present itself while they troubleshoot. Wondering if anyone else is having this issue.
