FordPass 4.28.0 update
Received 4.28.0 today for my Android phone, testing in process today/evening.
Ford F-150 Lightning FordPass 4.28.0 update 1688588529629
Ford F-150 Lightning FordPass 4.28.0 update 1688588551430
Ford F-150 Lightning FordPass 4.28.0 update 1688588567778
Later this afternoon, we took a trip down town, when I started the truck, I got an alert that the following update is now pending to install at 1am overnight, assuming that's successful, I'll also be looking at any impact it brings.
Ford F-150 Lightning FordPass 4.28.0 update 1688607595451
Hank42
NY
2022 Lariat ER
I've had 4.28.0 for a while - It still has that stupid spinning "loading" circle. I don't use PAAK, so no feedback from me there. I can't see anything this is "broken" however.
suprsprm
Gus
New Jersey
Construction
I had phone as a key since October, donโ€™t understand this update
It's supposed to improve the experience of new users setting up PAAK, I guess most of use early adopters will not see anything regarding this improvement, but hopefully others who have not tried PAAK yet will have a better experience setting it up.
Gaalpwrd
Jeremy
Colorado
23 F150 Lightning #183/887, Lariat LR Antimatter
Building stuff
This one is supposed to work on the DC Fast Charging curve. Got it a few weeks ago and I guess I saw some improvement (it seemed like the charging curve got to max charge quicker).
My truck got the PAAK update last night, no idea if I had it already or not as I haven't tried to use my phone yet. I'll update FordPass today and give it a go after the kiddos go to bed.
suprsprm
Gus
New Jersey
Construction
Got it. Thanks. It was a pain to set up
So I tried last night and have no idea what happened. I hit the button on the app to start pairing. Before I got farther along I realized I had BT off, so I quickly toggled it back on. Upon BT turning on I suddenly got an email that I've activated PAAK on my truck. Cool, but when I went back to the app the button now says Resume Setup. So I hit that, then it says my phone is not fully compatible, I have an S23+...how is that not compatible? I hit continue and then it wants me to rename my phone because their is already one paired with that name. At this point I gave up fiddling with the app and tried to figure out how to set the password. I could not find anywhere on the app or in the settings menu and was too tired to look it up at this point so I went to bed.
IIRC, passwords /codes are input on the Sync screen.
I found the place to change the door code, but did not see an option for a password. Does it not show up if PAAK is not fully enabled?
I believe that is the case, I only set password when I originally set up PAAK.
