Range calculation stuck in towing mode???
chrisvitek1
2022 F150 Lariat
Sales
My range calculation appears stuck in Towing mode. So it displays approximately half of actual. I have tried selecting "no trailer" option under the Towing icon several times and cycled the power several times. Still stuck. Any suggestions?
Did you drive it after selecting no trailer?
Usually you don't need to drive it, but it's been a while since I had my trailer attached, and recent updates may have changed behaviour.
PA Lightning
Tbone
PA
Lightning Pro
Hail Mary fix.
Press the button for your trailer back up assist.
A message should pop up that it is detecting trailer, although one will not be connected.
Push the button to turn off the back up assist
Then go into your menu and select no active trailer.
Ford Motor Company
Official Ford Account
F-150 Lightning
Hey, Chris! I can take a closer look into this stuck in towing mode concern if you'd like. Can you send us a private message with your VIN and the dealership name/location? To send a private message, just click on our username and select "Start Conversation".
it's happened to me many times, and no 'reset' or any actions within the menus will change it - you just have to 'wait' for it to EVENTUALLY work itself back to 'regular' truck range mode... aggravating, though.
Bsnead
Bryan
Lake Tapps, WA
2022 Lightning
The same thing happened to me. I had detached the trailer while the truck was still on. I had to hook the trailer (electrical) back up and turn the truck off then disconnect. That reset the remaining miles back to normal.
Interesting observation. I’m going to see if I can replicate that the next time I hook up a trailer.
CRAIGC540
Craig
Moreno valley
Technician
I remember seeing a video where there's a setting in trailer settings you can reset the trailer to none.
mb0220
Matt
2022 Lariat ER
If your range estimate is stuck in trailer mode it has nothing to do with being in the "Tow/Haul" driving mode. The problem is you still have an "active trailer" selected. To recalculate You have to go into the Towing app from the home screen, and then go to select active trailer, and choose "no active trailer".
In the original post, he stated that he did exactly that and it didn’t work.
johnnycombo
john
Pennsylvania
2022 f150 lightning
electronic technician
Vehicle on, plug in trailer, select trailer on sync screen, vehicle off, unplug trailer, vehicle on, select no active trailer on sync screen.
Unplugging the trailer while the vehicle is on causes the problem.
Good tip, I'm guilty of leaving the truck "idling" while unhitching, I'll give this a shot.
I've experienced this 'range stuck' situation many times since I tow so often,,,, but,,,, it always eventually resolves itself on it's own... aggravating? yes. annoying? yes. a problem? no.
Pestsprayer
Joey
Bixby, Oklahoma
2022 Ford F150 Lightning PLTNM
PCT Service Manager
Hail Mary fix.
This worked for me!
