lakeguy55
- May 23, 2022
- New Hampshire
- 2023 Lightning Lariat, 2011 F-150, 98 Expedition
Yesterday I went into our local town about 8 miles away to run some errands. When I left, with no preconditioning, the temps were in the high 30's. We had the heat on, set to 70, both seat heaters set to max, fan on 3 bars, and the radio on. Upon arrival, this is what the trip report showed.
During the return trip, temps had risen into the high 40's, we had the heat off, seat heaters off, fan off, and no radio.
A pretty graphic example of the impact of temperatures and heater use on range over the same drive. Something to show those who don't understand why their range drops in the cold weather.
In doing this, I did come up with a few tangential questions.
Finally, a few miscellaneous questions that probably don't belong here but I haven't been able to locate answers elsewhere, primarily because I don't know what terms to use in a search.
What devices are included in the Accessories category? I didn't have anything on during the return trip that I'm aware of.
Is the External Temperature category a measurement of the energy used to keep the batteries at the right temp? I was somewhat surprised to see relatively high usage here on the return as the batteries had already been warmed up on the initial trip and temps were now almost 50.
On the left side of the trip display, what is the left-hand graphic that shows 82 telling me? Is this an indication of the percentage of battery available for driving as the remaining 18 percent is reserved for the other categories?
I just discovered yesterday (I'm a bit slow ;-) ), that the volume button ring can be pushed in and you can push on the any area of the ring. I assume this is used by some apps or functions of the truck. But I have yet to discover a use. Have I missed more or is it for future use?
