Reduced Power after update
emmelj
Jerry
DFW
2022 Lightning, 2018 Tesla M3
Receiving 1/2 power, only rear motor after update. No errors or notifications. Any suggestions? @Ford Motor Company
This does happen occasionally after updates. Turning the truck off and on again usually clears it.
MillieChliette
Happens occasionally. It's a glitch and it'll go away.
There's a thread on this probably once a week.
Glad you got it fixed, but for anyone reading the thread, don't immediately jump to pulling the 12v connections, let the truck have some time to settle in, there could be background processes that need to finish, pulling the power could brick your truck if done to soon.
Ford Motor Company
Official Ford Account
F-150 Lightning
Hi there! Will you send us a message with your VIN and your local Ford dealer? I can look into things on my end.
Adventureboy
I wholeheartedly second this!
For the 1/2 power thing, you need to leave the truck off for 10-15 minutes I believe. Off/On doesn't always work without the brief wait. I think it needs to allow the powertrain module to shut down which takes a few minutes after you shut it off.
Matt
XLT SR Avalanche
This is correct for at least myself. I tried it at a stop light and it went to 100% then bounced to 74 then finally at 64% again. I'll see if it's changed here in an hour from work.
emmelj
Jerry
DFW
Just curious if you got back to 100% after a while?
I drove it for the day. Same thing. start it up, 100%, then after putting it in drive, it would drop to 56%. That day, I had turned it off and on numerous times while running errands. Finally, disconnecting battery did the trick.
Adventureboy
Thx, this is good to know. I'll add this to my list of tricks for the Lightning if the symptoms are persistent.
