Using F150, CSP and HIS to discharge to a DC load
Runaway Tractor
Yes
I'm hoping that even without an actual HIS added to the account, and with an FCSP that isn't broken, it will still command the truck to close in the HVFC contacts.
That said, I'm not super confident that will happen. The terminals are labeled backup power. The FCSP even has status lights to indicate it is operating on backup power. I don't actually see anything that eludes to the 12v backup power blindly triggering contacts to close. I hope it does. Just seems a little odd that it would do that blindly.
DanielB
Daniel
New Hampshire
2023 Ford F150 Lightning XLT SR EG312A
When I was under the mistaken impression it was doing it over the power line, it seemed logical that it might just be simplified and automated. Now that I realize how convoluted the FCSP/HIS architecture is and the actual trigger occurs over Bluetooth I am doubtful. I guess fingers crossed still.
I wonder if we'll have better luck playing with something like Drawing power out of CCS port (V2x, inverse charging, bidirectional CCS) instead. I'm likely to just wait for one of these:
V2X Bi-Directional Charger
Wallbox Quasar 2
Enphase Bidirectional EV Charging
My preference would be a cheap EV charger with CCS1 connector that I can trigger the HVB charge contactors directly and homebrew the rest myself.
Runaway Tractor
Yes
It may also be possible for someone who has a HIS and wants to nerd out... to reverse engineer whatever RS485 comms are being send between the HIS and FCSP. Then it's just a matter of telling the FCSP what it wants to hear.
Jakebeans
Jacob
Nebraska
2022 Lariat 511A ER Black
Controls Engineer
Do you think it's actually RS-485 comms? Over the two contact connections? If I remember right, those are the pins it uses to communicate with DC fast chargers, but I also think it's a PLC protocol. Very confusing for someone who works in the industrial world, because PLC means programmable logic controller in my world. But I've fucked with (very rarely) RS-485 comms in the past, so if that's all it is, that would be cool. Something like Morbus would make the most sense. I don't remember her name off the top of my head, but she has a YouTube channel and she's on here, and she took apart her FCSP and the inverter had an RS-485 port on it, so it's possible that's what they're doing.
He’s talking about the comms between the FCSP and the HIS, not the truck.
Kenric
Kenric
Austin, TX
2023 XLT ER
There is 485 and another signal labeled PE. Wonder if that is something as simple as Power Enable?
Where do you see PE? Note that for the J1772 connector PE refers to Protective Earth, i.e., Ground.
Ford F-150 Lightning Using F150, CSP and HIS to discharge to a DC load 1713313662193-y
DanielB
Daniel
New Hampshire
Yeah, common wire for low voltage. From the Ford-Charge-Station-Pro-Installation-Guide.pdf:
Ford F-150 Lightning Using F150, CSP and HIS to discharge to a DC load 1713366056066-gt
windydrew
Kansas
23 Lightning Lariat ER
Solar Installer/Electrician
So I have a Lariat ER and FCSP and a Fronius Gen24 Hybrid inverter ready to accept 400vdc. Just need help figuring out how to get the truck to close the contactors. Any ideas? I applied 12v to the backup ports and it goes green but won't close the truck contactors. What else can I try?
Runaway Tractor
Yes
As far as anyone here knows, not possible. There is data communication between the Delta inverter and the FCSP by RS485 over twisted pair. Then there is bluetooth communication between the FCSP and the truck. Somewhere in that communication is what is telling the truck it's time to provide power and the contacts would close in. There is no known external means to trigger that. The backup power terminals and battery is just there to power the board on the FCSP. It is not what tells the truck it's time to provide power.
Grumpy2
Central Oregon Coast
23 F150 Pro SR
Retired Hvy Construction
That is the best answer. If the public could bypass all the safeties and access the unrestrained power of the 140,000 watts stored in that battery, all similar EV's would be recalled. Big Oil would have what they want.
windydrew
Kansas
Then I'll plan to replace the board in the FCSP in order to communicate directly to the truck using proper hardware made for bidirectional charging.
