sstevetx
- First Name
- Steve
- Sep 3, 2023
- Dallas, TX
- 2022 Lariat ER w/Max Tow - Atlas Blue
Here are the actual errors I received. I took it for a short drive and I didn't get any popup errors in the instruments cluster. Tried PMI on each of the failed modules and the PCM telling FDRS I didn't have the original module, so it would download the config from Ford. Errors still showed up even after clearing them. The one bit of good news is that installing the modified frunk beeper back in got rid of that FHCM error. I just removed the black/ground wire inside the frunk beeper and taped it off then put it back together. No beep and no FHCM error. Truck is charging now, so I am not sure if those errors will cause any observable issues or not.
