Can you precondition on roadtrips without using Ford Navigation?
PreservedSwine
Fort Myers
2023 Lightning
I use Apple CarPlay for Nav. Does this communicate the same as using Ford Navigation when traveling to a charger as my destination? As I have come to understand- you just have to trust that the truck is preconditioning, and there is no way to manually determine if it is… or isn’t.
Took a little trip last weekend, but was only charging at ~70KW, trying to determine why so low, and if using CarPlay and Apple Maps instead of the built in navigation had anything to do with it.
Also- it was 90 degrees outside- temps on dash right in the middle.
CarPlay is aware of my battery status at all times.
Thanks.
CyclopsThere
Portland
2023 XLT
My salesperson said to type the destination in via ford nav IN ADDITION TO carplay so that the car can do its thing properly. It's a workaround at least
No, the only option is to use FordNav and point it to the DCFC (or a nearby one if heading to a SC).
mb0220
Matt
2022 Lariat ER
As far as I know you cannot have a destination programmed into two nav systems simultaneously.
CyclopsThere
Portland
2023 XLT
Hmmmm interesting, I wonder if that's a software update new thing, or a screen thing? I'm in a XLT so have the "split screen" and can run google maps in the main pane and ford nav in the subpane
sotek2345
Engineering Manager
I just ignore it, the few times I have used the built in Nav, I haven't noticed any appreciable difference in charging rate (maybe a minute or 2 total charging time).
srspring551
Scott
WI
F150 Lightning Lariat 2023 ER, delivered 10-28-23
Is Summer "preconditioning the battery" an actual thing? :unsure:
PARKED :No, at least from my experience in moderate New England summer, garaged away from sun. All the energy I see is related to cabin conditioning or topping off the battery if you don't have highly restrictive TOU time windows.
DRIVING: I've haven't done much hot weather tripping, but I had great charging curve performance a few weeks ago, using Ford navigation directly to an EA station in the Berkshires.
Ford F-150 Lightning Can you precondition on roadtrips without using Ford Navigation? 1722541408807-i8
Ford F-150 Lightning Can you precondition on roadtrips without using Ford Navigation? 1722541533576-hq
Labs4Lightning
C
Labs4Lightning
C
