Ford - Is a Lightning NACS Plug Addition possible?
Steveel
Steve
Washington
2023 F150 Lightning ER Lariat
Mechanical Engineer
I saw a review on a Lightning delivered to Norway. Part of the conversion for Europe was adding a port in the false door to charge. They did not list the added cost. Might have to search for that review.
Steveel
Steve
Washington
Mechanical Engineer
COPowderskier posted the review on the forum.
rdr854
Northern Virginia
Yes, but my recollection was that the drivers side port was closed off. It is important to note that the truck had to be reengineered/modified for the European market in order to meet technical and EU requirements.
Steveel
Steve
Washington
Mechanical Engineer
Yes this is true but people may give up CCS and go with NACS. I am sure software could handle whatever port was selected. I don't think it would be cheap to do however.
There is zero chance of this happening IMO. Both Tesla and A2Z have said they are developing an extension.
flyct
Jerry
South Florida
Blissfully Retired
I just charged at a Tesla site today. Fortunately the far right Tesla stall had an empty parking spot to the right. I parked at an angle and I took up one Tesla spot and one other standard parking spot. I still had to pull up at an angle and my front end was right next to the Tesla charger.
My feeling is even if a Lightning charge port were positioned where it would only take up one Tesla spot the Lightning‘s extra width would be an issue with the Tesla narrow spots. The only Tesla spots that appear to be able to easily handle a wider vehicle are the Handicap spots at some Tesla sites.
GM is putting in Chargers at local Pilot Gas station. Their spots are massively wide compared to a typical Tesla charge station.
Europe uses CCS2, not NACS, so those parts won’t apply here.
Danface
Dan
Central Mass
2023 Lightning XLT
Just an idea...an adapter with a cable (maybe 6 feet long) could be an easier solution. A problem could be that it would have to either work with Tesla's thermal management system or have really, really heavy gauge wire. There are probably other issues too, but it can be fun to brainstorm.
After all, a second adapter in the truck will have to have about the same size wires running inside the truck. Wires outside aren't necessarily that different.
I spoke with a guy who works for one of the charging platform providers, the cable is most expensive part of Level 2 chargers.
RickKeen
Rick
F150L SR Pro
sw engineering manager,
An extension could have its own cooling system, but not clear if that would be cheaper than using thicker wire. But it would need to be some kind of larger thing with a radiator and a fan (like the truck itself).
That inspires the idea that If building an extension / port relocation into the truck, cooling the cables that carry the high currents could be tied into the vehicle's on-board cooling system.
flux capacitor
2023 F-150 Lightning
How about they just build charge stations that look like ICE stations where it does not matter where your charge port is you can just stop your vehicle where it works best. ICE's have had fuel ports in every imaginable place. They put them on the tight side, left side, and centered in the bumper in the back. In the 50's they use to hide them behind tail lights and other hidden places. All stations were able to accommodate anything even when pulling a trailer.
Not quite:
Ford F-150 Lightning Ford - Is a Lightning NACS Plug Addition possible? EXTENSION_NACS
Bigisland Guy
Ed
So Cal
Retired Old Dude
As cords are being developed, wanted to share that in the Netherlands and other Euro countries regular public level charging stations don't have a cord, the EV driver supplies their own. This offers the charging ability while reducing cable theft. Perhaps as things progress here in the states especially in urban areas where vandalism is a problem we might switch to this method. If we do then the powers that be should also design L3 and beyond consumer cables.
RickKeen
Rick
F150L SR Pro
Not quite:
The A2Z extension appears to be going without active cooling which means thicker conductors to keep the resistance and heat down. Its not a shipping product yet, so not sure that photo will be what it really looks like. My prediction is it comes in shorter - like only 2m (6') long to hit their cost/price target with all that copper its going to need to stay cool enough.
Also they talk about active thermal "monitoring" which is another word for throttling.
You will notice the power rating of the extension is not yet published. Its likely going to be limited by current, not overall power. (i.e. 250 amps at 800v = 200 kW, but 250 amps for 400v vehicles like the Lightning is only 100kW).
The tradeoff might be you can reach the charge port, but you can only charge at some reduced current levels.
Hopefully they can get it up closer to 500 amps that us F150 Lightning owners really want.
MTcowpoke
Montana
Many diesels and a Lightning
Rancher
I've posted this pic before. Can you even imagine the cost to add just the hardware for a NACS on the other side?
Ford F-150 Lightning Ford - Is a Lightning NACS Plug Addition possible? Charge Port
