Powertrain malfunction/reduced power
In my case the whole thing was replaced. ER platinum.
Can you share the work order list of parts (redact any sensitive information)
Victorog
Victor
Houston TX
2023 f150 lightning
Construction
Will do once I get it back probably tomorrow or Monday not sure yet.
KK10
Colorado
2022 F-150 Lightning Lariat
Ironically, I just had this happen to my 2022 Lariat ER today, powertrain malfunction and power is only 57%. This is rather frustrating, the three dealers I called said approximately two days to diagnose and then they will work on the problem. None of them offered loaners. @Ford Motor Company
Victorog
Victor
Houston TX
2023 f150 lightning
Construction
Unfortunately ford does not offer loaners. It’s at the dealerships availability and or discretion sadly.
GoodSam
Good
occupying space
Ask for rental/gas reimbursement from Ford BEV team 800-392-3673 if a battery module replacement is needed?
Kaiserkal
Charlotte NC
F150 lightning XLT ER
Hey all,
I've been getting the same power train warning that's been posted in this forum, So I won't repost the issue.
However, I am not getting the high voltage warning, just the power train/reduced power warning..
The first time it came on, it stayed on for about 4 days. It then went away. I called my dealership because they had no availability online and then when there was availability, miraculously the error went away that day of the appointment. I called and asked what they can do without the light on and they said pretty much nothing.
A few weeks later, same issue but it only happened until the car was turned off (SEP 3rd). This happened again this past Friday (SEP 27th) and got an appt for Sep 30th. Brought it in, they said they think they know the issue on Monday, did nothing on Tuesday, drove it today (Oct 2nd) and the light didn't come on. So they don't have a fix for it at this time or a diagnosis.
Really unfortunate. If this happens again, I will have to start a lemon request. The last thing I want is to have the issue above where it says 'pull over immediately' as I have a 1 year old and another baby on the way. It may sound ridiculous, but that kind of issue on the highways near me which are very busy and always under construction would cause a serious accident.
Otherwise, I completely love the lighting. But figured I should post the warning as well to other owners, since it seems like a common issue. Of course, while at the shop and they can't diagnose the issue and won't give a loaner (and if they don't find an issue the loaner comes out of my pocket based on what I read above).
It's been a very poor experience to say the least.
Lytning
Georgia
Hey all,
If you have not contact the BEV team, I would highly recommend that.
Ford Motor Company
Official Ford Account
Ford
F-150
Hey all,
Hi there! I can look into your Lightning's error message concern on my end. To get started, could you please send a private message over with the name/location of your local Ford dealer and your Lightning's VIN
Victorog
Victor
Houston TX
2023 f150 lightning
Construction
Hey all,
Hello,
It appears your truck is warning you ahead of the pending possible breakdown. I would have your dealer reserve you a loaner now. Ford dealerships generally have to purchase vehicles from ford so it is really up to the dealer to provide you a loaner. Secondly the lemon laws are tricky. The manufacturer would have had to have fixed the same problem three times and it remains a problem. Also the manufacturer would also look at the depreciation on your vehicle, miles, wear and tear. It really isn’t that simple. But from my experience your batteries are going bad. These lightings do very weird things.
Kaiserkal
Charlotte NC
Or been in the shop for roughly 30 days for a problem they can't solve over the course of 12 months.
Still, that's not very positive sign if it's warning of a possible bigger future problem at 6k miles (now near 8k)... I see you had the same issue and had a battery array issue. Hopefully, I don't have the same issue. When/how was your dealer able to fix it? Did the light have to stay on when you got it to them or was it after?
Got in contact with the Ford team above ? I'll update if there is ever a solution that is positive. Hopefully everything goes well, a problem is fixed, and it's back to good health soon where I don't need to worry about it.
Victorog
Victor
Houston TX
2023 f150 lightning
Construction
Hello,
I got my truck back after 7 weeks. The battery array from time of order to delivery is about 4-6weeks. The light was on and the vehicle was on a tow truck top speed was 3 miles/hr. My truck was at 9600 miles. My local dealership has had trucks go dead at 2300 miles.
jamelski
Sacramento
2024 Lariat
I got my 2023 lightning in march of 24 with 200 miles and 9k plus miles later I get a power train malfunction/ reduced power message and could not drive the truck. Took family to the mall. I had to remove the 12 volt battery to reset, this was a week ago. Well tried to park the truck properly this evening and the same problem again. This is exhausting, repeated the same process to get it to move. Taking it to my dealer this morning. I can’t imagine it happening while my wife or kid was driving.
I’m confused your truck said 0% power on left of screen why would you do some truck trick re set vice going to the dealer from the beginning ? The truck told you multiple times the car was messed up, but you kept driving it? Then you’re gonna get mad when you finally decided to go to the dealer and the truck crapped itself.??‍♂.
Victorog
Victor
Houston TX
2023 f150 lightning
Construction
Not sure what you are getting at, if you paid over $90k for a vehicle you wouldn’t be disappointed? the choice I had was to sit at the side of the road 5 hrs away from home, get a tow truck back home or leave the vehicle at a dealership in the middle of (nowhereville) be completely messed up with my family in the truck or think fast by resetting the battery??‍♂ The power gauge is constantly between 0% and 100% basically shows the power usage when you step on the accelerator just like a gas engine. What you should have said was that it was at 4% power, please get your facts right before you make statements. It makes you look like you do not own this electric vehicle. Attached are the before and after pictures of what it looked like then and now after repair. And I do have a bad tire sensor new issue which just showed up when I took that picture, FYI it appears and resets itself. Before you try to point that out!! So please I don’t need to scolded like a child. We are all on the forum to share information with each other thanks!!
Ford F-150 Lightning Powertrain malfunction/reduced power IMG_5459
Ford F-150 Lightning Powertrain malfunction/reduced power IMG_5158
Church
Michael
NW Tennessee
2023 Lightning Lariat Ext. range
County Health Director
Hello, I would like to see if I can assist you with your powertrain concerns. Could you please send us a message with your VIN and mileage?
I'm having the same issue if you can assist.
vin 1FT6W1EV8PWGxxxxx
Ford Motor Company
Ford
F-150
Hi there! Would you send us a private message with your VIN and dealership name and location? I’d like to look into this concern on my end.  
